Old 10-20-2022, 12:32 PM #1
psea17 psea17 is offline
psea17 is on a distinguished road
AutoTech Alternator & Battery Gassing
Anyone running one of these alternators w a flooded lead acid battery? mine puts out a very steady 14v. seems it might be causing the battery to gas excessively.
anyone experienced similar?
is there something i could put inline to get a lower float voltage when the battery is fully charged? i think the alternator may be overcharging.
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 10-20-2022, 01:23 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb will become famous soon enough ArthurKotb will become famous soon enough
ArthurKotb's Avatar
Real Name: Rich
Have you checked to see if you have a dead/weak cell? If you do the battery will not reach the float stage.
Rich
2004 V8 4Runner 130K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 10-20-2022, 02:07 PM #3
battery is brand new.
the last one gassed badly and died but that one was neglected by 2 cs144 alternators that went bad.
Manual Transmission
Old 10-20-2022, 03:17 PM #4
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough
Moderator
fourwd1's Avatar
You need 13.8V minimum to charge a battery, 14V should not be a problem. My '84 alt puts out ~15V and never had an issue with a battery.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 10-20-2022, 03:52 PM #5
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
Mine puts out between 14.3-13.6V and have no battery issues. If the battery is brand new I would suspect a manufacturing defect.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 240K miles.
326WHP 347TQ
Old 10-20-2022, 04:00 PM #6
just to be sure, i checked all cables for resistance, went back and sanded off paint where the frame ground is located, redid my body ground by adding a rivnut screw sized for 5/16 lugs, cleaned all contacts, add dielectric grease on all lugs/terminals and re-did the alternator's positive cable lug at the battery. it wasnt good.
so i guess I'll wait a bit to see if the gassing damage (corroded connections) was actually from the old battery.
appreciate all the input. sounds like a steady 14v to an FLA battery isnt an issue.
Manual Transmission
Old 10-21-2022, 11:17 AM #7
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Is there a different voltage regulator for that alternator? If it's a high amp alternator it may need a matching regulator.
BTW, dielectric grease is non-conductive. it's purpose is to prevent high energy spark from going where it shouldn't. It probably won't make a difference on your battery terminals but don't put it on your spark plug connection, only on the plug boot. :-D
Rich
Kentucky
Old 10-21-2022, 11:23 AM #8
it is a hi output alternator. but dont really understand the implications of the point youre making.
is there a specific question i should ask the manufacturer or certain features the regulator should have?
appreciate any further info you could share.
Manual Transmission
Old 10-21-2022, 01:56 PM #9
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
I was just wondering if the new alternator had an internal regulator. I'm not up on alternators and thought maybe if the OEM alternator had an external regulator that it might need to be changed as well. I would expect the voltage at the battery to change, particularly right after startup. There would be a heavy drain on starting, high voltage until it reached maintenance level, then remain between 12.7 and 13.1.
While 14 is a little high, it's not bad. As long as you're electrolyte level is okay then you're good to go. If you're constantly adding water then maybe you do have an issue.
Rich
Kentucky
Old 10-21-2022, 02:15 PM #10
voltage was much higher when i started it (14.6 +/-) in the morning but quickly returned to 13.9-14v within a minute or so.
guess I'll call autotech and see what they say about the regulator, if any.
Manual Transmission
Old 10-21-2022, 04:48 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Charging voltage 13.8 to about 15v would be fine. you start heading to 16 volts you are getting too high. I wouldn't be concerned at all for ranges in the 14 volts and bouncing around at times. :-)
Old 11-28-2022, 09:47 PM #12
Hey guys,
An update....As best I can tell, my problems originated from the pos cs144 alternators. They weren't charging well and my battery was damaged. putting a solid alternator in just exaggerated the battery's death.
I redid my positive wire from alternator to battery. I also redid all grounds. i'm starting to find having a rivnut tool is the bomb!! Now that there's a new battery, I'm not having any problems. Battery stays charged. There's no corrosion on any contacts after a few months and there's no battery gassing.
I'm very happy w/ the autotech alternator's performance.
regards,
Manual Transmission
alternator , battery , excessively , experienced , gas
Bad battery or alternator? StreetCreeper 3rd gen T4Rs 41 11-12-2019 03:48 PM
new alternator, battery runi9 3rd gen T4Rs 8 08-12-2019 10:50 AM
Battery? Alternator? Zackadeez 3rd gen T4Rs 10 11-23-2013 04:13 PM
Bad Battery and/or Alternator??? mustangaustin34 3rd gen T4Rs 6 12-14-2009 11:04 PM
Battery or Alternator? Krystle Classic T4Rs 0 11-30-2009 07:41 PM
