03-23-2015, 04:43 PM
Real Name: Alex
Real Name: Alex
Rust holes on my roof, how to fix?
So I bought my 4runner about 2mo back. I knew it had some spots on the roof that were more on the bad side than good. The underbody was in great shape though so I wasnt too worried and figured I could fix it. Been doing a ton of maintenance and upgrades and now figure its time to take care of the roof issues.
So I have 4 main spots I need to fix. Driver side front roof rack rail, center rear there are two spots, and then one at the rear of the passenger side roof rack rail.
My plan is pretty basic. Take off the headliner to make sure its not worse than it looks, then just cut out these sections. Unfortunately I just downsized and got rid of my welder so the only way I can weld in sheet metal is if I take it somewhere and im not a fan of taking my trucks anywhere for work, id rather do it all myself if possible. So I was thinking of just glassing sheet metal into the holes, then filling with body filler, sanding and painting. I watched some youtube vids and a couple people recommend doing this but im not sure if its really the right way to do it.
Any opinions, or other ideas on how to fix these spots? Appreciate it
12-17-2019, 10:41 PM
I’m sorry. I know it has been years since you posted this but I’m having the same issue with my 99 4Runner. The roof is rust in a few places and I want to know how did you fix it
I would appreciate the help
Thanks
12-17-2019, 11:03 PM
Cut the fiberglass bs and get new metal welded in.
12-19-2019, 09:41 AM
Real Name: Jon
Real Name: Jon
Oh boy. You probably have only a few options there.
The main concern would be to seal the hole.
1)A patch would be to use silicone and seal the hole so water can not get into the cab. Granted, this is temporary and not a permanent fix. Will work for a while.
2) fiberglass screen and body filler would seal the hole then you could sand it down smooth and paint it with touch up paint.
3) weld steel plates over the holes and use body filler to smooth it up then paint with touch up paint.
4) Reskin the roof by replacing the panel. You would have to drill out all the spot welds and weld the new roof skin on.
12-19-2019, 11:33 AM
Of the 4runners I’ve played with the racks on they all had those same holes with white square plastic inserts in them.
Anyone know the purpose of those? They seem to be doing nothing. But I’ve never pulled a headliner.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
12-19-2019, 01:50 PM
Real Name: Jon
Real Name: Jon
I believe they hold the trim and the rack on. Those plastic squares are under the limited cladding too. To help hold that cladding on.
12-19-2019, 02:51 PM
Real Name: 3 Bears
Real Name: 3 Bears
if the holes are small I wonder if something like JB weld would work ? If you do it clean and your putting the rack back on maybe the rack and its rubbber gasket would cover it.
12-19-2019, 04:30 PM
I found them. They are to help hold the plastic end caps on. Now I kinda think the plastic end caps I was working with didn't have the nipple that is supposed to insert into those plastic clips. Maybe broken off in the past.
The inserts are PN# 62759-35010.
12-19-2019, 04:38 PM
buy a cheap lincoln on offerup or craigslist and go to town. Make sure you use gas and not a flux core if you want a clean setup. Id just place a round disk under it then weld that disk inplace from the outside then bondo to fill in the void of the disk then paint. no fiberglass, no no.
12-19-2019, 06:29 PM
Real Name: Jon
Real Name: Jon
The welder better know how to weld on rusted metal to pull this one off. You are working with 20 gauge rusted steel. However, this method will work with metal underneath
Fiberglass screen with bondo will fill the void too. Those holes are too big to just use body filler. Most people do not know how to weld nor will they want to pay someone to weld it for them.
However, its up to the OP on how they want to fix it.
12-19-2019, 11:21 PM
Real Name: Tony (no surprise)
Had to think for a while as I had something similar before.... Just remembered. I had two FJ-40s back in the day and the roof on one was pretty bad. Not easily repairable. I simply removed the roof, used it as a dog house for my Akita actually! Drove it with no roof for years, rain or shine. So, if you ever thought of going roofless, maybe adding a cage...
2000 Limited, E-locker
Maintenance/Build Thread
12-20-2019, 01:03 PM
I got bubbles in the roof, it seems the previous owner just painted on top of it. Will bond fix that?. Also one of the screws was broken (last one on the rail, and the first one too as well ) beginning to think i made a bad decision. Please help
12-20-2019, 01:31 PM
no. you will have to remove the paint and the rust to see how bad it is. once removed you should have it welded up. bondo is crap.
same with the OP, other than reskinning the roof, the only proper way to do this is get all of the rust out and get it welded back up.
99 4runner limited; imperial jade mica
IG: mesooohoppy
12-20-2019, 02:42 PM
How much would i expect to pay a shop for something like that? I stop by a shop close to my home but they say $1,200 for lowering the inner roof , welding and painting the roof which i think is a little steep
