Old 10-23-2022, 08:06 PM #1
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Axle nut not threading onto remanufactured CV axle
Got my CV axle swapped out, seals replaced, and everything else torqued back down to spec and now the axle nut won’t thread onto the axle. I have the nut from the previous axle that I was trying, but I read in a few places that they should be replaced every time they are removed. So I went down to the Toyota dealership and bought a brand new one with the same results. I’ve even tried lightly filing the threads to open them up a bit, but the nut just gets super tight almost immediately. Wanted to get some input before I pull out the hacksaw and start with some fresh threads. Thanks guys.
stevew092984 is offline   Reply With QuoteReply With Quote
Old 10-23-2022, 08:42 PM #2
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
Does the nut from the old axle thread on ok if it does just use that one if it is not damaged. The new axle should have come with a new nut, I have used the old one many times with no problems. Some reman axles use different thread patterns from stock.
214RUNNER is offline   Reply With QuoteReply With Quote
Old 10-23-2022, 09:00 PM #3
It doesn’t thread on at all, will barely start and then gets super tight. That one will still thread on the old cv axle like butter. The remanufactured axle did not come with an axle nut. I’m kinda stuck on what to do here.
Old 10-23-2022, 09:07 PM #4
214RUNNER's Avatar
214RUNNER's Avatar
I would go back to were you bought the axles and have them get you one that fits. like i said the new axles should come with a new nut
Old 10-23-2022, 09:19 PM #5
Wish I could. Bought them on eBay, but I did send them a concerned message, so we’ll see how that goes. The axle seems fine, I just need a dang nut that will work for this. Was just wondering if others might have had a similar issue and found an alternate nut that can work with this.
Old 10-23-2022, 10:21 PM #6
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Someone probably hit the end of your new axle with a sledge when they were removing it from their vehicle and mashed the outer threads a little bit before they sent it in to be re-manufactured. Try holding the old axle threads next to the new axle threads and see if the thread pitch is the same. You may have to run a M28X1.5 die down it to rebuild the outer threads.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 10-23-2022, 10:34 PM #7
They seem to be about the same pitch, but it doesn’t feel like it when I’m wrenching it down. Even tried using a tiny file to open up the treads a bit more, but it didn’t seem to help. I’m contemplating cutting a couple threads worth of metal from the shaft to get a fresh set of threads. Just worried that it still might not work and then I’d be stuck with the axle because I cut it and can’t return it.
Old 10-23-2022, 11:00 PM #8
That really sucks. Who is the re builder? Sounds like they didn't check the threads. There's not many threads to be cut off between the end of the axle and the cotter pin hole. I'd order a die and fix the threads or return the axles.
1997 Toyota 4Runner
Old 10-24-2022, 12:33 AM #9
I’m in the Bay Area and they’re in Arizona. I bought it on eBay from Desert Toyota of Tucson. This is my daily driver, so now I gotta take everything apart again and put the old one back in so I can get to work and stuff. Just sucks having to waste all of this time because of one nut.
Old 10-24-2022, 12:01 PM #10
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
They should warranty the axle and cover the shipping back. The nut should go on smoothly. I wouldn't try to make that work. It's their responsibility to give you a quality product.
You're in my area and I get a discount at Stevens Creek Toyota. I could maybe meet you at the dealership parts department and you could use my discount to buy an axle from them.
Old 10-24-2022, 01:47 PM #11
Hey Tim, yeah I could meet you there at the parts center. I’m just a few miles away from there. I see the part listed on their website for $316.09, but don’t they charge more when you go into the parts center and buy it rather than ordering online and then picking it up? I saw the knuckle oil seal online from their website for like $50 and when I called in to check if they had the part, they said they did, but it was like over $100. Anyways, yeah lemme know when to meet you there and I’ll make it over.
Old 10-24-2022, 06:07 PM #12
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Send me an email and let's exchange numbers. If you give me the part numbers you need and I'll call them to get my price on them.
Here's my email: [email protected]
axle , i’ve , nut , replaced , threads
Q: Replace axle bearings&seals or find assembled axle? Mutant 3rd gen T4Rs 12 09-14-2017 10:35 AM
Remanufactured cv axles from Detroit Axle used assassin 4th Gen T4Rs 14 06-27-2015 09:28 AM
Solid Axle Swap vs regular axle w/ lift/suspension? priestsallore Classic T4Rs 9 04-28-2010 11:30 PM
