Old 10-27-2022, 05:48 PM #16
Originally Posted by JohnMc View Post
Lambda is the direct WBO2 sensor reading, it's the measure of how much oxygen remains in the exhaust. That is interpreted by a gauge to show an AFR value, but that interpretation involves some assumptions about the fuel, and generally speaking most gauges (unless you deliberately reprogram them) will be expecting you to have burned gasoline.
But the number, even though technically not the correct AFR for ethanol or E85, is still useful for tuning. 14.7 is still stochiometric if you're burning gas or E85. There's no real need to convert it to an actual E85 AFR.
That said, E85 acts a little differently, and using a regular setup AFR gauge or not, you might want to do some different tuning under boost. Either way, really, it's more resistant to detonation, so you might not need to run as ruch under a given level of boost. And alternatively/contradictory, it will keep adding more power a bit richer than gasoline will, so if you're really wanting max power richen it up more than you would with gas.
Sorry, how can E85 and pure gasoline be 14.7 lamda? The more alcohol weather it’s methanal or ethanol lowers the optimum AF.
Old 10-27-2022, 08:26 PM #17
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Great explanation. My AFR sensor uses only Lambda and the AFR ratio it shows it just an interpretation of the Lambda reading. The thought that you have to richen it up 30% more than the desired 11.8 target AFR isn't quite right though as the extra octane lets you run leaner. For example, I had my engine tuned at 11.5-.8 AFR when on 91 octane fuel. I then added water/methanol 33/66 mix sprayed through a 3gph nozzle. The engine made max power at 12.1 AFR so I actually leaned up the tune from the extra octane! Hope that helps in tuning for E85.
326WHP 347TQ
Old 10-28-2022, 09:35 AM #18
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
Originally Posted by 19963.4lsr5 View Post
Sorry, how can E85 and pure gasoline be 14.7 lambda? The more alcohol whether it’s methanol or ethanol lowers the optimum AF.
I presume this was just a typo. JohnMc likely meant to say that a lambda reading of 1.0 is stoich for all fuels.
All WBO2 sensors read in lambda, and some can be set to display in AFR. Since it's common for most gauges to be setup for gasoline they will convert lambda 1.0 to an AFR of 14.7 by default.
If you are running ethanol or some other fuel blend, the sensor will still read stoich as lambda of 1.0 and translate that to 14.7 AFR. So for all practical purposes you can tune ethanol on the gasoline AFR scale as long as you understand the readings are actually in lambda.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 10-28-2022, 11:41 AM #19
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I'm saying the a WBO2 gauge will read 14.7 on a perfect stoichiometric burn, whether it's methanol, ethanol, E85, or gasoline. Because it is NOT measuring AFR, it's measuring the lambda, the remaining O2 in the exhaust. And the gauge itself, without any input, has a conversion built into it to convert the lambda reading from the sensor into a derived AFR number.
So, sure, a stochio burn on ethanol is a lower AFR. But a WBO2 sensor will read it the same as a stochio burn on gasoline at a higher AFR number. And the gauge will convert that lambda number to a 'gasoline AFR'. Because it's built to assume you are burning gasoline, since the vast majority of people are burning gasoline.
On some gauges you can plug into them and reprogram them so they will read the proper AFR number for whatever fuel you are using. But I'm not really sure that makes it easier to use.
So unless you've reprogrammed the gauge, just think of it as a stochio gauge, with 14.7 being the middle, anything lower is rich, anything higher is lean. Regardless of the fuel used.
JohnMc is offline   Reply With QuoteReply With Quote
Old 10-28-2022, 12:52 PM #20
I guess a simpler way to say it is that if you have a proper stoichiometric mixture on E85, the actual AFR will be around 10 (9..8). But unless you've messed about with it, your AFR gauge will show 14.7, it will NOT show 10.
Old 10-28-2022, 02:11 PM #21
I did it: E85 on a Supercharged T4R
So with e85 what does the lamda value equal for 10:1af? Using gas as the lamda
I’ve seen monitors that you can program lamda for the fuel being burned. My brother and I use a WEGO that we can input a few sensors to it for logging purposes. MAP and TPS.
Old 10-28-2022, 06:08 PM #22
So with e85 what does the lambda value equal for 10:1 AFR? Using gas as the lambda
I’ve seen monitors that you can program lambda for the fuel being burned. My brother and I use a WEGO that we can input a few sensors to it for logging purposes. MAP and TPS.
The lambda reading is independent of the fuel type. Stoich is always at 1.
Because all gauges read in lambda (AFR is for display purposes only) it can be easier to tune with the native lambda value, then you don't have to worry about fuel type.
E85 stoich is right around 9.8:1 so a 10:1 AFR like your example question will read close to 1.
Since most gauges only have AFR curves programmed for gas, you won't see a 10:1 AFR displayed when running E85 - it'll still say 14.7. That's why, like mentioned before, it's important to remember the sensor and gauge are actually always reading lambda. The AFR displayed is just a calculated number.
Old 10-28-2022, 06:18 PM #23
You may be thinking of it backwards. Lambda is the measure of the O2 left in the exhaust. It's independent of the fuel being used. It's what you can look at as an indication of a rich, lean, or stoich burn. You can't tell what the AFR was by looking at the lambda reading in the exhaust, all you can tell is rich, lean, or in between.
And FWIW, a WBO2 sensor puts out voltage between 0 and 5 volts. 5 being waaay lean, 0 being waaay rich. It's not a completely symmetrical curve between full lean and full rich, lambda of 1 (stoich burn) is often (it can vary dependingont he sensor) around 2.1 V.
So with gas or E85 or a mix in between, a stoich burn (10:1 E85, or 14.7:1 gas) will read as 1.0 lambda, around 2.1, 2.2 V from the WB O2 sensor.
The gauge looks at that voltage, and does some math internally to convert it to an AFR number. It can't tell from the WB sensor what fuel was burned. So someone has to have set it to do a conversion from a direct lambda sensor reading to a contrived/derived AFR number. Which assumes you are burning some particular type of fuel.
So there is no E85 or gas lambda, lambda is the same regardless of fuel. The gauge does math based on what it fuel it thinks you are using to calculate an AFR number. So if your gauge is set to gasoline, a 10:1 AFR is stinking rich, regardless of what fuel you are using. If your gauge is set to E85, 10:1 is stoich, regardless of what fuel you are using.
Generally, I'm not sure what the advantage of changing the gauge setting around would be. Because E85 isn't always E85 (at least not pump E85). So it won't necessarily be an accurate AFR number anyhow.
Just treat it as a rich/lean gauge, with 14.7 being right in the middle. Regardless of what fuel you use.
Old 10-28-2022, 07:14 PM #24
Originally Posted by turbodudey2 View Post
The lambda reading is independent of the fuel type. Stoich is always at 1..
I’m my experience Stoich is always 1 based on the fuel type.
A person running strait methanol with an AF of around 6:1 AF which is a stoich of 1 for that fuel type is different than e85 or strait gasoline.
Using a AF monitor that reads stoich instead of a AF number what is the reading going to be with a gasoline calibration of 14.7:1 which equals a stoich of “1” when they are running e85?
I’m not trying to argue with you. Just trying to hammer out the variation between different AF monitors and what the optimum reading should be for those with a meter reading stoich instead of an actual AF ratio.
Leaner is meaner until one puts holes in their pistons. Been there too many times.
Old 10-28-2022, 08:05 PM #25
Stoich will be 1 lambda, regardless of the fuel.
Stoich will be 2.1V from the WBO2 meter, regardless of the fuel.
What an AFR gauge reads based on that input, is all up to the gauge.
Old 10-29-2022, 09:40 AM #26
Is appears I must revisit this.
Old 10-29-2022, 11:27 PM #27
FJ60GatewayDrug FJ60GatewayDrug is offline
FJ60GatewayDrug is on a distinguished road
This album has the LTFT at various points. High idle / cold start, low idle / cold start, low idle / warm engine. Plus an engine run up to about 2000RPM.
LTFT E85 - Album on Imgur
I took a look and didn't see any obviously damaged/cracked hoses.
0.514 lb/min is 3.886 g/s, which you read at 704 RPM. I had 3.6 g/s at 756 RPM. Given the variation of intake temperature and elevation, it seems to all be matching up.
I'd run another couple tanks of 91 through it for comparison and to check my LTFT against E10 gasoline, but... I gotta save my pennies for a clutch
FJ60GatewayDrug is offline   Reply With QuoteReply With Quote
Old 10-30-2022, 11:12 AM #28
I know my TPS in the off idle to around 20% (10-20%) is worn some. It’s got 293k miles on it and I’ll catch the LTFT at 15-18% in a three to five percent zone and instantly drop back to around zero around 18%tps. I have some spare sensors but haven’t gotten around to changing it.
Old 02-18-2023, 12:05 PM #29
Update
The ratio of ethanol and gasoline varies by season. In the winter, there's more gasoline. In summer, more ethanol. This is to help cold starting. Here in SoCal, the difference is pretty minor, but I have noticed that I haven't seem to set a "too lean" code in awhile. I'm also regularly mixing in 91 and not doing straight E85 unless I've got a long trip planned. (Remembering that idle seems to be where E85 "struggles" the most, causing the fuel injectors to go over +20% fuel trim) MPGs continue to be crap, albeit slightly more crap when it's a tank of mostly E85.
An oil analysis from Blackstone came back clean, with wear matching other 5VZ-FE samples. I'll do another analysis next oil change, too, and see if there's any changes.
Also, I did pull a spark plug out and checked out the #4 cylinder, because it was in the middle and represented a good blend of heat soak but not hottest coolant, exhausted into the bank where my aftermarket AFR gauge reads from, and was the easiest to reach. I took photos, but they're photos of a screen, since the cheapie unit I have doesn't capture pictures natively. No visible deposits, or the entire thing is coated and looks like a new protective layer has formed; either way, the pictures-of-the-screen pictures aren't great. I'll dig them up and post them if people really want to see what a 200k+ mile piston top looks like.
Old 02-18-2023, 08:52 PM #30
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Pics, please. I definitely want to see them!!!!
Sent from my SM-S908U using Tapatalk
e85 , ecu , engine , fuel , trims
98 Supercharged on CL Ifirefight 3rd gen T4Rs 12 11-07-2018 11:35 PM
Anyone looking for a Supercharged 3rd Gen? dfranchuk08 For Sale: Vehicles 0 06-21-2016 07:41 PM
Supercharged 5th Gen Omega88 5th gen T4Rs 25 12-26-2014 02:44 PM
For those who are looking for a supercharged 3rd gen... hondafmx1000 3rd gen T4Rs 6 01-17-2012 12:32 AM
3.4 supercharged 410toy 3rd gen T4Rs 15 03-05-2009 10:05 PM
