Old 10-25-2022, 11:54 AM #1
Johnny0's Avatar
Johnny0 Johnny0 is offline
Johnny0 is on a distinguished road
Johnny0's Avatar
Troubleshooting help needed - JDM engine installed and starter wont engage
My son just finished installed a JDM engine in a 99 2wd limited 4R. used the harness and parts off the US spec engine.
when the key goes into ignition the door chime rings but no power to the dash warning lights or stereo. turn the key nothing happens at starter. we put a mulit meter on the little wire to starter and nothing when key is turned
we tried other relays and checked all fuses.
I wonder if ECU immobilizer?
My son said there was water in neutral safety switch from flushing heater core when he plugged in the harness
Any and all thoughts or advice on solving this is welcome
thanks
2000 SR5 Sport 4Runner 4x4 5vze w/5 speed manual
Millennial Silver paint. Moon roof, Cloth Moon Mist interior
Still stock but not for long
Johnny0 is offline   Reply With QuoteReply With Quote
Old 10-25-2022, 11:59 AM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Verify the park neutral safety switch is functioning properly. ;)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 10-25-2022, 03:21 PM #3
nissanh nissanh is offline
ACC position still should turn on the radio regardless of the PN switch is connected or not. Door chime works because it has a separate wiring (direct current from the battery). did you try all Bussman (high amp/thermal) fuses? Theses are inside the main fuse box in the engine compartment and well known to burn during engine installation/Starter installation.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 10-25-2022, 04:04 PM #4
Oswald_89 Oswald_89 is offline
Oswald_89 is on a distinguished road
I'm the son.
To give some more information, I have checked all of the fuses, replaced the park neutral safety switch. I still need to verify it's good and properly adjust it. To add to the problem list, the windows in the vehicle don't work, climate control doesn't work, hazards work but not turn signals. what I'm finding weird is, while the gauge cluster does not register when the key is turned, I can read the live data for the engine with our obd2 reader when I plug it in and the key is in the on position. I would assume power is getting to the ECU, but who knows, I could be wrong, maybe I missed something in the fuse blocks.
Oswald_89 is offline   Reply With QuoteReply With Quote
Old 10-25-2022, 08:53 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
All this from changing an engine? I changed an engine and transmission in my 1997 limited with no circuit issues. Please tell me you used the chassis engine and transmission harness that matches the rig exactly.
Old 10-26-2022, 12:48 PM #6
I didn't change the harness, it's the one that came with the truck
Old 10-26-2022, 02:48 PM #7
Most things you've said runs on direct power (ignition off).
At any point did you get the alternator Battery post shorted to the ground?
Old 10-26-2022, 03:05 PM #8
that is a possibility, I went through a couple days ago and cleaned all of the grounds I could find on the truck, the alternator ground had some oil and road grime on it. I cleaned it up/sanded it to get bare metal and put it back on
Old 10-27-2022, 10:30 AM #9
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
i'd try rechecking that all the plugs at the ECU are fully seated and locked into place
clearock is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 10:49 AM #10
If your OBD scanner can connect to another vehicle then the problem is still the ECU or the power going to the OBD connector.
Old 10-27-2022, 09:37 PM #11
thanks everyone for your help, I ended up diving into the fuse block a little deeper like Nissanh suggested and found that the 120amp bussman fuse for the alt was fried. once it was replaced the truck started with no issue. crazy how that little thing can prevent an entire motor from starting
engine , harness , installed , key , starter
4wd Wont Engage A_HuL 4th Gen T4Rs 31 07-29-2021 05:53 PM
new engine installed.. how wont start..help scott_morris70 3rd gen T4Rs 10 05-01-2017 09:37 PM
ac compressor wont engage TOYO 4R SR5 3rd gen T4Rs 30 12-18-2016 11:35 PM
4x4 wont engage miheckman 3rd gen T4Rs 0 11-11-2013 03:47 PM
4x4 wont engage when hot rica4runner 3rd gen T4Rs 2 03-14-2012 04:41 PM
