Old 10-27-2022, 08:09 AM #16
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
Originally Posted by gamefreakgc View Post
I hate to be a downer but $7000 for a 4Runner with 300K miles on it is not worth it. You are overpaying by several thousand dollars.
I was immediately leaning toward this when I saw the list of repairs made within the last 5,000 miles. I mean, good maintenance is key, but if the seller doesn't have a good reason for doing all of that work and then selling it shortly after, then it would raise some red flags with me. A few of the repairs listed are basic maintenance on a vehicle that old (shoot, I've done these too), but they could also indicate a problem that the previous owner is still chasing.
Ah, the fun of buying a used vehicle...
All below w/in 5k miles:
New Timing Belt/Water Pump/Thermostat/Pulleys
New OEM Gas Cap
New OEM Radiator and Hoses with coolant flush
New OEM Evap Canister and evap hoses
New 1x OEM Ignition Coil Pack
New OEM Spark Plug Wires
New OEM 2x Lower Ball Joint (both sides)
New OEM Clockspring
New OEM Intermediate Steering Shaft
New Fuel pump
New Spark Plugs
New Valve Cover gasket (upper and lower)
New Power steering pump
New Rack and Pinion
New Leather Seat Upholstery for Driver and Passenger Seats
aontkos is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 10:12 AM #17
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Need 3rd gen purchase advice please
Good old parts cannon!
Well, there could be some valid reasons. They may have been chasing evap issue. It could also be that the guy just wanted everything baselined. I am kind of that way with mine, I just change everything.
Maybe they ran out of money? Maybe they decided that old vehicle ownership wasn’t for them? Maybe they couldn’t figure it out? Maybe they got divorced? Maybe it was funded by Biden Bucks? Who knows.
Regardless, I would at least make sure that the OBD monitors I have completed their run cycle. I realize that not everybody knows how to do that. I just carry a little blue driver dongle with me and plug it in and scan the vehicle. If the monitors have been reset, then I’ll throw up a few flags. I use that to my advantage, though I don’t view that as a problem, depending on what else is going on that said, my pricing is adjusted accordingly and I do so in cash with a willingness to walk if I have to.
It’s probably worth discussing just to make sure people don’t have their rose colored glasses on. But, I think expectations probably need to be realistic. These vehicles are incredible and about as reliable and long-lived as it possibly gets. But, there’s still things that it will require if you want it to be at a high level of fitness. I bought mine with way more miles in rough condition, but I also bought it pretty cheap at $2000 because it had issues. All fixable, and everything but the bodywork done by me. My $2000 4runner is more like a $10,000 4runner now….eeek! I probably should total up my receipts, one of these days, but I’m scared to look. But it’s armored, has a nice suspension, a winch And what not. It’ll be really nice once I get this front suspension job done hopefully this weekend. I have like $1500 in new cat converters to install while I’m there too. I really hope I can get the rusty nice loose on the manifold, otherwise that’s gonna be a fun job.
I think where potential gaps occur with individuals is when a person buys an old car, and expects a new car experience Without being able to do the work themselves or just being independently wealthy I guess to pay someone else. To me, my ownership experience has been fantastic. And yes, I’ve done a lot of work. In fact, I just got finished replacing all of the seatbelts in the car. the last guy that owned it acted like it was a nightmare for him, because he had to spend too much at the repair shop with drive lines and a steering rack …… so it’s all relative I guess. I don’t even know if I had to pay somebody for all this work or what it would even cost. Oh, Lord, I can’t even imagine. I would easily have 10 K, in just labor, maybe more. But it’s all really fresh now. Lots of new parts throughout the whole vehicle. engine and transmission run fantastic, but if I get to the point where it’s not, it won’t be a big deal. I’ll pull them out, re-power and go again.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 10:23 AM #18
Romeo1's Avatar
Romeo1's Avatar
Originally Posted by Bad Luck View Post
You’re quite welcome! Limited trims for 96-00 use an electric actuator to shift the transfer case in and out of 4wd. My previous 4Runner was a 2000 limited and the transfer case always took some time to shift in/out of 4wd. Most of the time it took several shift attempts to get it to change. I exercised it frequently in the hopes that it would get better but it never did. My current 4Runner has a standard j shift so no electric shift motor for the transfer case at and I’m much happier with it. My experience with the limited transfer case seems to be less common. It’s my personal preference.
I would highly recommend shifting it from 2hi to 4hi to 4hi locked and making sure the system is operating like it should before buying it. The 4wd indicators on the instrument cluster will go solid once the requested transfer case setting is achieved. If it flashes give it about 10 seconds or so before putting it back to the previous setting and trying again. I found that changing settings while driving was the most likely way to get it to shift.
DO NOT ATTEMPT TO SHIFT BETWEEN HIGH AND LOW RANGE WHILE MOVING! ONLY SHIFT BETWEEN HIGH AND LOW RANGE WHILE STOPPED AND THE TRANSMISSION IN NEUTRAL!
Parts only for the mods listed including wheels and tires would be around $4000 give or take. That’s not including any labor costs if he had a shop perform any of it.
I am kind of a J shift fan myself. I don’t have any experience with the other style. An open transfer case all wheel drive would be super sweet to have though for the high speed rally. But I’ve had too many bad experiences in my life with electronic four-wheel drives Dating back to the 90’s Chevys. Makes for a sucky day when your electronic four-wheel-drive leaves you in a terrible pickle. Since then, my policy has always been mechanical four wheel drives. What sucks is now practically every vehicle is an electronic four-wheel-drive these days. Even the ones with levers, most of them are just moving an electronic actuator.
My work tundra really caused me some hell here a couple years ago over a unit wheel bearing causing issues with the ABS speed sensor. Somewhere in the FMVSS wisdom, they decided that if yaw control isn’t able to be maintained, we’re just gonna limp everything out in the name of safety. I would argue vehemently that the opposite is true. It’s a huge safety issue doing that as you could be up in the mountains somewhere, have a tire chain wipeout a speed sensor wire, and then your super EFFED. I’ll because some pencil D@&$?!ed bureaucrats decided it’s for the children…..
Shit, even the Jeeps now are having electronic issues as guys have to buy a taser harness to work around the stupid Dana sensor that will prevent lockers from working. That’s a shit day when you’re in the middle of some rock garden in your lockers decide not to work because of the federal motor standard baby!
Old 10-27-2022, 10:25 AM #19
flygirl0344 flygirl0344 is offline
flygirl0344 is on a distinguished road
Originally Posted by Romeo1 View Post
Well, what’s the condition of the rest of the vehicle on either one?
I bought mine with like 365k. But I got it cheap cause it had issues that I fixed myself.
I kind of like mine unmodified, but that’s just me. That said, it does have lots of the right mods. Who ever did it did their homework or knew why they were doing.
Here’s the .. issue.. the truck is 5 hours away from me so i haven’t seen it in person yet. It looks solid from the pics but you know how that goes. I have a cpl undercarriage vids and the owner shifting from 2wd to 4wd but I can’t get them uploaded..? And of course I wouldn’t buy it site unseen.
Need 3rd gen purchase advice please-aae8e75d-f7b3-4573-9715-13ac58b68aff-jpg  Need 3rd gen purchase advice please-46352e61-bd39-429f-b84c-eb4ebb45b056-jpg  Need 3rd gen purchase advice please-5ce9e472-d74b-4507-ad9a-59b7579fa96a-jpg  Need 3rd gen purchase advice please-378bfc9a-127d-4d57-bd2e-c99a16bbc3cc-jpg  Need 3rd gen purchase advice please-5f572a04-19e7-41e1-b2c6-45f13210fb25-jpg  Need 3rd gen purchase advice please-e9f8c853-953b-43a5-87a6-3cd70900dd45-jpg  Need 3rd gen purchase advice please-2443f61f-dfff-4a65-80fb-2e81296f725f-jpg
flygirl0344 is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 10:28 AM #20
Does either one have an e-locker? That would maybe be my biggest thought if your planning and actually wheeling it. Not the end of the world if not, but a great place to start from as that pushes you into 4.30 gears also.
No e lockers..
Old 10-27-2022, 10:30 AM #21
[QUOTE=aontkos;3766913]I was immediately leaning toward this when I saw the list of repairs made within the last 5,000 miles. I mean, good maintenance is key, but if the seller doesn't have a good reason for doing all of that work and then selling it shortly after, then it would raise some red flags with me. A few of the repairs listed are basic maintenance on a vehicle that old (shoot, I've done these too), but they could also indicate a problem that the previous owner is still chasing.
Antkos, supp he’s having a baby and they got a van so this needs to go.
Old 10-27-2022, 10:36 AM #22
…I would highly recommend shifting it from 2hi to 4hi to 4hi locked and making sure the system is operating like it should before buying it. The 4wd indicators on the instrument cluster will go solid once the requested transfer case setting is achieved. If it flashes give it about 10 seconds or so before putting it back to the previous setting and trying again. I found that changing settings while driving was the most likely way to get it to shift.
I have a cpl vids of the owner shifting 2wd to 4 Wd but I can’t get them to load. Can we post vids here?
Old 10-27-2022, 10:39 AM #23
I hate to be a downer but $7000 for a 4Runner with 300K miles on it is not worth it. You are overpaying by several thousand dollars. There's no guarantee that the engine and transmission will last much longer at that stage. I do think the previous owner did do a lot of the big maintenance items but that's 300,000 miles over what, 21-25 years? So it has been driven roughly 12,000 to 15,000 miles every year for over two decades? That means bearings are worn out. The bushings are worn out. It will creak, rattle and things are coming loose. All rubber hoses are deteriorated. The engine is losing compression. The valves will be out of spec. The transmission clutch plates are worn out (if an auto). Need I go on? Sure, he replaced some items and upgraded the suspension but there's a lot more to a vehicle than that.
I see most major engine damage happening between 300K to 400K miles. I think you'd be buying a time bomb. Go for a lower mileage 4Runner.
The Toyo dealership will do a buyer ck for $185. Could they confirm or deny all of what you listed?
Old 10-27-2022, 12:26 PM #24
desertegal7 desertegal7 is offline
desertegal7 is on a distinguished road
how to tell you need regearing? drive the car and of it feels slow then needs regearing. (according to my knowledge)
high milage 300k is raising a lot of speculation, how ever age is just a number, mine 300k+ and running strong.. some pass 150k and they are in bad shape, its about how it had been used and look after.
i would advise to check engine yourself and maybe to compression test to get the accurate image about its health.
desertegal7 is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 01:33 PM #25
Romeo1's Avatar
Romeo1's Avatar
[QUOTE=flygirl0344;3766943]
That makes sense, this was probably a passion project for them and now life changes happened.
7K doesn’t buy much these days though, unfortunately.
It looks really straight from the photos. That’s a huge plus. obviously I need to see it in person to really make a good judgment, but I don’t think I’d be scared by it.
Maybe the question we all should really be asking you here is what level of appetite do you have for fixing things? Maybe I missed it somewhere else, what are you planning to do with the truck? Daily? Adventure rig? Both? Just cause?
Old 10-27-2022, 01:46 PM #26
game freak, this is all great info to consider. I def dont want any major issues with this after Im driving it home 5 hours. Thanks for sharing!
Old 10-27-2022, 01:54 PM #27
Romeo, what are your thought on what gamefreak said regarding potential issues:
"....That means bearings are worn out. The bushings are worn out. It will creak, rattle and things are coming loose. All rubber hoses are deteriorated. The engine is losing compression. The valves will be out of spec. The transmission clutch plates are worn out (if an auto). Need I go on? Sure, he replaced some items and upgraded the suspension but there's a lot more to a vehicle than that. I see most major engine damage happening between 300K to 400K miles. I think you'd be buying a time bomb. Go for a lower mileage 4Runner"....
Old 10-27-2022, 08:11 PM #28
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
They could, the biggest thing would be a compression check. Other things like worn bushings in the control arms, sway bars, etc. they may not check for as they can't check everything for $185.
I agree with the comment above and it does very much matter if you are able to do your own repairs. It is assumed that at 300,000+ miles you're going to have things break. I've purchases a few junker 4Runners over the past 5-6 years and parted them out and most engine failures I saw happened without warning over 325,000 miles. I bought one with a cracked piston like that. The thing still ran though!!
These 4Runners have a great reputation of lasting a very long time which is deserved. The problem about buying one is that this last owner was only one of many and we all have no idea how it was treated or taken care of before he had it. I do agree in that the list of maintenance items provided he was looking to make it last for a very long time. For example, I bought mine from the second owner. The first owner babied it like it was a collector's car and the second owner (a young guy, younger than me) absolutely thrashed the motor and drove it like it was stolen. I am still repairing damage he did to it during his ownership, and I bought mine at 190K miles.
326WHP 347TQ
Old 10-27-2022, 08:34 PM #29
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I'll chime in
If the seller can provide receipts and records then it might be worth it. For the reasons bad luck mentioned, I'm not a fan of the limited model transfer cases nor do I care for leather seats, but that's a personal preference
I'm not impressed with freedom off-road upper control arms, they don't do anything for suspension geometry other than change the angle of the ball joint and in all honesty a 2 inch lift doesn't require it.
I am a fan of 33 inch tires, 255/85 R16, and I don't mind e-rated tires considering I'll drop down to 8 PSI and ride the sidewalls, most folks not crawling don't have that requirement and can benefit from the weight savings of c rated tires
Like has been said, I would not go through the trouble of re-gearing unless you add a bunch of additional weight (armor, bumpers, winch) or have a use case, like rock crawling, to support the expense of changing gearing. If you were to pick up a factory e-locker with 4.30 gearing, it would be worth changing the front differential because that's a great ratio with 33s on a DD.
I would almost rather buy the lower mileage truck to perform all of my own mods and maintenance, that way I know it's done right. 300K miles doesn't scare me on these vehicles, however. Overall condition, does matter.
The last thing to consider are the things not easily changed, like interior color, equipment package, and rust. Buy the truck you like with the least amount of rust, damage or bs.
That's my take
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 10:47 PM #30
Romeo1's Avatar
Romeo1's Avatar
Well. I mean he’s not wrong. It’s going to probably need some more work if a high level of vehicle fitness is desired. If not trying it’s whatever. Mines in my garage right now getting ready for a full front end overhaul. Oem lower arms, JBA uppers, wheel bearings, and I’ll probably order an ECGS bushing tomorrow since mines a bit loose. My lowers are so shot now. Not only is the rubber visibly garbage, the steering changes upon hard braking from the lowers being so worn. My passenger tire even rubs the firewall on hard high speed hits while rallying from the flex.
Is a problem? No. Only problem I really have is the time to fix it. I’ll pulled apart this weekend and re condition it and it’ll be fantastic. So to me no it’s not an issue, I fix it and move on with life. Yes, it helps that I have the tools and the knowledge to do it. But anyway you cut it it’s still cheaper than a payment. I’ll rebuild the entire front end better than stock for what, 2 to 3 payments on the newer one?
Thing is, everyone has such a good resource available to them in the form of Timmy, the Toolman YouTube videos. They are practically a step-by-step with all relevant information, tips and tricks, torque values, the whole bit. An absolute incredible resource for somebody who maybe doesn’t know or have the knowledge or manual to go by. I used to get paid to turn ranches, and I still Tim and Sean’s videos.
I know this is a long winded response to your question. But there are no guarantees in any of this. It could be bulletproof and you drive it for another 300 K. It might die next week.
Sure, it’s very likely there’s going to be lots of little things that might need to be addressed. Things like hoses for vacuum. The heater valve is probably corroded. It’s like a 10 minute fix if that. The radiator might need swapped. It’s $130 radiator and you can swap it in like 30 minutes.
We’re not trying to discourage you, we’re just trying to keep it real in here, that’s all. I think it’s important to probably buy the best one you can afford. I’m kind of an odd duck that way and I look for the ones that have problems to go use that to my advantage in purchasing for less.
Like I mentioned, earlier, overall interior condition/color, level of rust, and how hammered it is in general to me or the biggest things. I can fix the rest easy enough.
Now, if the goal is to buy it, never ever open the hood on it, and just drive it, that expectation may be difficult to be met. All things being equal, lower miles is always nice.
3rd , evap , gen , mods , oem
Need Some Advice on 4th Gen Purchase JMat 4th Gen T4Rs 17 02-28-2020 09:53 AM
Pre-purchase Advice Patrick A 5th gen T4Rs 32 05-05-2019 12:13 AM
Advice on 01 purchase sonjason 3rd gen T4Rs 4 12-30-2017 09:51 AM
Pre purchase advice Frogman16 3rd gen T4Rs 11 03-02-2012 03:01 PM
Help me.. Need advice on new purchase.. sandSStorm Classic T4Rs 4 09-05-2006 05:03 AM
