Blew the alternator fuse doing a spark plug change, too embarrassed to say how.
1. Disconnect battery! (had I done this for plugs wouldn't be writing this)
2. Disconnect main wire lead on top-front of fuse box
3. DO NOT remove the 3 bolts retaining the fuse box. I did this based on other posts and you will loose the leverage required to pull the inner/removable fuse box.
4. To release the tabs pry them inward toward the CENTER of the fuse box. I hate it when it says "release the tabs"!
5. As a solo job I found it best to work the front tabs to get it started, work the back tabs, and back and forth until it comes free. You can find some "grab" points for needle/regular pliers to get a grip. There are two "sliders/guides" one each in front/back. They are like inserts that fit into the outer box. They will help you see your progress on each side, I also wonder if some silicone on these and the tabs would make it easier.
6. Once detached you should have enough play to remove bolted fuses.
7. Put it back together, no tips yet since I need to go buy the fuse
