Old 11-01-2022, 02:10 PM #1
4runn34's Avatar
4runn34 4runn34 is offline
Real Name: Justin
4runn34 is on a distinguished road
4runn34's Avatar
Real Name: Justin
HVAC Blend Door Actuator P/N??
I took my 4runner to get the AC fixed earlier this summer. The mechanic after looking at it said the "blend door actuator" was missing so I can't switch from heat to AC. He said to come back later in the fall to get the heat turned on. Well I would rather just source this part and install it myself. Does anyone know the part I'm talking about and the part number? Rock Auto was zero help.
1999 Toyota 4Runner Limited
4runn34 is offline   Reply With QuoteReply With Quote
Old 11-01-2022, 06:02 PM #2
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
87106-35070. Confirm it by adding your Vin in the Toyota parts catalog.
Old 10-14-2024, 12:48 PM #3
JerryD JerryD is offline
JerryD is on a distinguished road
Actuator 87106-J? Easy Spray-On Solution?
My 2004 V8 Ltd has an odd movement on the passenger side 87106-J or -L actuator. I pulled the glove box out and watched a white plastic object very gently and barely audibly spin back a few mm, then forward a few mm, over and over. It's been doing that for months, and yeah, no cold air on the drivers side. Figure it is the blend door actuator.
The actuator does look like it is the -J because it is mounted like an old fashioned computer hard drive - vertically in a metal cage.
It's just odd that it would do this. Is there some kind of default calibration that I can activate by pulling a switch or fuse?
JerryD is offline   Reply With QuoteReply With Quote
Old 10-14-2024, 03:30 PM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
Originally Posted by JerryD View Post
My 2004 V8 Ltd has an odd ...
This is the 3rd Gen forum - you'll get better results in the 4th gen.
Can an admin move this over please...
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
actuator , blend , door , heat , part
Blend door actuator stuck dphflytyer 3rd gen T4Rs 32 08-11-2024 08:06 PM
Blend Door Actuator H1_VLTG 4th Gen T4Rs 24 06-23-2024 06:34 PM
'04 Blend door noise? Actuator or something else? atalarico 4th Gen T4Rs 5 06-24-2022 09:00 AM
Blend door actuator or ? DMX512 4th Gen T4Rs 0 09-29-2017 09:30 AM
Can the blend door be adjusted in the HVAC? buchaja 5th gen T4Rs 3 01-03-2015 02:27 PM
