Originally Posted by 96RedRunner
FSM says 7-9 clicks of Lever max travel, less than 7 too tight more than 9 too loose
from experience this has proved correct with my brake jobs.
Jack wheel off ground turn by hand should hear a light scrub of drum on shoes.
That part I know but what I’m asking is let’s say my brakes are adjusted properly, if I just keep yanking on the Ebrake will it eventually tighten the shoes too much and cause them to rub while driving and heat up the drums and wheel . I’ve heard that at a certain point they will not keep adjusting out and that you basically keep pulling the Ebrake till you don’t hear the adjusters moving anymore
