Old 11-04-2022, 05:02 PM #1
jaxinmontana jaxinmontana is offline
jaxinmontana is on a distinguished road
No start after head gaskets and valve adjustments
Hi all - I recently had a head gasket failure on what appeared to be the 3rd cylinder on a '97 with 3.4L. I replaced the head gaskets, adjusted both intake and exhaust valves to spec, replaced the timing belt, etc. Now I have a no start.
All timing marks are matched up exactly. I get orange spark from single electrode NGKs, and the plugs are wet with fuel. I replaced both the camshaft and crankshaft sensors. The 3x ignition coils are fairly new, after market, and so are the NGK plug wires. The engine went back together appropriately torqued with no parts left over. Before I started the project, compression tests were all over the place and still are off.
Any additional thoughts or ideas on this subject?
jaxinmontana is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 09:01 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If your compression is suddenly varying and wildly inconsistent then it has to do with timing. If compression is varying and there's no start, my first guess would be something like a cam position sensor being unplugged or going bad (if just recently replaced most likely the connector isn't fully seated, but it's still possible to be DOA, I've had knock sensors arrive DOA directly from Toyota). If you're getting spark, fuel, but no ignition AND varying compression, I would almost put money on it being a cam timing issue - but that's just my preliminary guess - I don't know about you but my 4Runner LOVES to have other parts suddenly crap out while trying to fix a related problem in a way very similar to what you described, so from my experience I wouldn't be super quick to start ruling things out
Old 11-04-2022, 09:10 PM #3
ZSW99 ZSW99 is offline
ZSW99 is on a distinguished road
Double check the plug wires are connected in the right order. Sounds basic but I’ve screwed it up before. If they’re good I’d do resistance test on the cam and crank position sensors and the coils. If that’s good I’d double check the valve adjustment. They could be too tight and staying open some I guess. That would be an kit of work to go back into but you could check everything under the intake when you have it off
99 SR-5 Highlander Elocker, 1.5” body lift, Ironman FCP coilover, FJ cruiser bilstein lift coils and fj80 kyb rear shocks, JBA ucas, TC gussets, custom front & rear tube bumpers, poly bushings all around, 33/12.5/15 on steels. 396k
98 Base 4x4 3rz. 5100s and ome coils. TBU. 360k
96 Taco rcsb 4x4 3rz 320k
ZSW99 is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 09:46 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My signature has a link to a thread with the wiring diagram etc on coils wires and spark plugs.
Old 11-04-2022, 10:11 PM #5
spartacus's Avatar
spartacus's Avatar
Double check the coolant lines going to throttle body as well.
gaskets , head , replaced , start , timing
Blown head gaskets prevent engine start? Mauka.net 4th Gen T4Rs 8 08-11-2019 10:38 PM
Crap!! Replaced Knock Sensors & Valve Cover Gaskets - Truck won't start!!! denvermaxd 3rd gen T4Rs 33 09-28-2018 03:54 PM
Valve adjustments thisisme1371 4th Gen T4Rs 6 04-27-2015 12:34 PM
Changed Valve Cover Gaskets, Now Wont Start Trout_Bumz Classic T4Rs 5 11-21-2010 03:02 PM
Valve adjustments on '03 V8? Swaro 4th Gen T4Rs 2 05-30-2003 02:04 PM
