Old 11-07-2022, 05:11 PM #1
greembow greembow is offline
Real Name: Kiwi
greembow is on a distinguished road
Real Name: Kiwi
No high beam indicator after installing LED headlights
Hi there, I have a 1998 SR5 V6 without DRLs. I recently installed LED headlight bulbs and now my high beam indicator doesn't work. What should I do?
greembow is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 05:44 PM #2
The high beam indicator is powered THROUGH the low beam filament. No low beam filament (LED) = no high beam indicator. This can sometimes cause issues with aftermarket headlight harnesses too.
Load resistor(s) are your only option, basically.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-07-2022, 07:37 PM #3
My harness from Amazon keeps the high beam indicator working through the low beam coil. It’s not as bright as it would be going through the bulb.
It should be fine to power an led bulb through my harness as long as the led bulb used the stock base
Old 11-07-2022, 07:41 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
using the sticky in the top of this forum you can search to see if other threads exists on a topic that you want an answer on. :-)
For example:
site:toyota-4Runner.org/3rd-gen-t4rs/ beam, bulbs, high, indicator, led No high beam indicator after installing LED headlights
Will result in a pile of results on this topic.
You need either a load resister or your need Leds that have resistive loads built into them that mimic an element of a bulb to have your high beams function again. As phattyduck stated.
LED bulbs in certain light circuits will cause unintended side effects and I am wondering if they can cause some circuits fuses not to work properly. As their have been instances of melt downs without the fuses blowing due to the nature of the LED being a diode and stop current from flowing or only one direction in 3rd gen 4 runners.
beam , bulbs , high , indicator , led
High beam indicator wire under dash bittwiddler 5th gen T4Rs 29 02-19-2024 05:05 PM
High Beam Indicator - What Triggers it? DaMonkey 3rd gen T4Rs 35 11-06-2022 03:36 PM
High Beam indicator on dash not working. Trapper-Randy74 3rd gen T4Rs 3 10-20-2020 08:23 PM
high beam indicator intermittent issue Slobo 3rd gen T4Rs 8 08-10-2018 02:08 PM
high beam indicator hrt4me 3rd gen T4Rs 6 10-09-2012 06:22 PM
