Old 11-11-2022, 06:27 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Originally Posted by Brian1973 View Post
Old one. sorry it's rotated... turn your head to the left.
Yes that one is done.
I do you rear two you are going to have to loosen the others so you can lift enough to change them.. :-)
Old 11-11-2022, 07:23 PM #17
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I might be more worried about the mount and rust? that is kind of a lot of cancer? none of that stuff is coming off without fire and a lot of bacon.
you can still get a lot of the toyota body mounts
the big bolt 5221735030 BOLT, BODY MOUNTING
4 little bolts for the mount to frame 9164281025 BOLT, W/WASHER
5220935011 CUSHION SUB-ASSY, REAR END BODY MOUNTING, UPPER
9020110099 WASHER, PLATE
9418401001 NUT
frame parts
5170935030 BRACKET SUB-ASSY, BODY REAR END MOUNTING
5170635030 BRACKET SUB-ASSY, CAB MOUNTING, NO.3 LH
I would bet with a little digging you can find the frame brackets, but that will be some welding on the frame.
Old 11-11-2022, 08:14 PM #18
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by cblock406 View Post
It's not a hard job, and yes you need to pull back the carpets to get to the bolts. And you need the spacer for the rag joint. I did new body mounts the same time I did a one inch body lift, you know, since you are already in there...
Same
In my opinion and experience, the one inch body lift helps not only with clearance issues, tires and suspension components, but keeps aftermarket bumpers at bay
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 11-14-2022, 06:34 PM #19
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
I'm using these... What needs greased? Couldn't find rubber bushings. :-(
9.4102G Universal Polyurethane Body Mounts Bushings Isolators, Include 4 Plated Metal Washers, 2 Plated Metal Sleeves, 4 Body Mount Bushings(Black) https://a.co/d/8fYL3hZ
Universal definitely is not the right choice here. You can get the rear body mount by itself in a direct-fit application... Or a full set of poly mounts.
Grease wherever metal touches poly or poly touches poly.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
body , frame , pull , side , wondering
Regarding the OEM body mounts . . . 1985taylor1925 3rd gen T4Rs 11 12-18-2021 05:37 PM
Body mounts: too much weight? Mudeprived 3rd gen T4Rs 26 11-29-2020 12:29 PM
Polyurethane Body Mounts without Body Lift ChildrenOfBodom 3rd gen T4Rs 18 02-21-2016 08:05 PM
Polyurethane replacement body mounts with body lift opinions? ellner357 3rd gen T4Rs 0 02-02-2013 12:42 PM
Body mounts Brutus 3rd gen T4Rs 3 03-21-2010 12:53 AM
