Originally Posted by Brian1973
Old one. sorry it's rotated... turn your head to the left.
I might be more worried about the mount and rust? that is kind of a lot of cancer? none of that stuff is coming off without fire and a lot of bacon.
you can still get a lot of the toyota body mounts
the big bolt 5221735030 BOLT, BODY MOUNTING
4 little bolts for the mount to frame 9164281025 BOLT, W/WASHER
5220935011 CUSHION SUB-ASSY, REAR END BODY MOUNTING, UPPER
9020110099 WASHER, PLATE
9418401001 NUT
frame parts
5170935030 BRACKET SUB-ASSY, BODY REAR END MOUNTING
5170635030 BRACKET SUB-ASSY, CAB MOUNTING, NO.3 LH
I would bet with a little digging you can find the frame brackets, but that will be some welding on the frame.
