11-10-2022, 02:34 PM
Aging Body Mounts
Need to replace the frame mounted bushings on both sides of my frame of my 2000 4R at the back. Wondering the easiest way to do so? I have taken off the nuts on 3 rear (of the 5 per side mounts). Jacked up under a sturdy section of the bumper. Am able to raise the body but I'm wondering if there are things I need to be concerned about? After raising it a few inches seems I still need a few more and don't want to stretch anything or snap anything. Figured doing one side at a time. Would seem maybe easier to be able to pull the long shafted bolt up from inside the cab but I'm thinking I would have to pull apart the interior carpet in order to do so making this an even bigger job...
2000 SR5 3.4L 4WD
Aux-12v "always on" mod, DRL mod, 2 Tranny coolers
Rear Differential "extended" Breather mod,
ScanGuage II, 231mm Tundra Brake upgrade,
ABS mod
11-10-2022, 03:03 PM
Curious as well. What do your mounts look like? Or rather why do you think you need to replace them?
11-10-2022, 03:29 PM
You are far better off taking the edges of the carpet up to remove the bolts than to try and lift the body high enough to clear the bolts from the mounts. You will stretch or pull something if you don't.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
11-10-2022, 03:30 PM
hanging around this one as well...
Are you using OEM rubber? Any part numbers by chance?
I get a little lost looking them up and can't always tell what's what.
Build Etc...
If it ain't broke, fix it 'til it is.
11-10-2022, 04:47 PM
It doesn't take much to pop up the sill trim and get access to all the bolts. Don't lift more than necessary to pull out the rubber portion of the mounts from the divot they sit in. Make sure both sides are loose, but only lift one side at a time. If you are putting on poly mounts, make sure they are greased.
Here's mine - you can see that you only need about 1" to 1.5" above the frame to do all the work. Any more and lots of things need to be disconnected:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-10-2022, 07:08 PM
Do a body lift while replacing those body mounts...
11-10-2022, 09:46 PM
Originally Posted by brillo_76
I am curious if the 1 to 3 inch body lifts change the center of gravity much?
I've got a 1" body and haven't noticed DRASTIC changes in my center of gravity. I mean you can't take a corner above 20 to 25 miles an hour, but that's about it really. I'm happy with what I've got but I don't think I'd go higher than 1.5" if I were to do it over again.
Sent from my SM-S908U using Tapatalk
11-10-2022, 09:49 PM
I think the big things to worry about are the steering rag joint and the lines going back to the rear heater from what I've seen in the videos talking about body lifts. Maybe fuel and brakes lines too? Timmy the Toolman has a good video on it. I'm still surprised that my 270k 3rd gen the body mount bushings are still quite supple, was checking those yesterday when I was greasing the zirks.
'98 SR5 5 Speed
11-10-2022, 11:44 PM
Real Name: Dave
Real Name: Dave
Glad mine looks good.
11-11-2022, 11:31 AM
Real Name: Christian
It's not a hard job, and yes you need to pull back the carpets to get to the bolts. And you need the spacer for the rag joint. I did new body mounts the same time I did a one inch body lift, you know, since you are already in there...
11-11-2022, 01:25 PM
Unfamiliar what a rag joint is? If my main objective is the 2 rear mounts, figuring on just unbolting the 3 of 5 per side towards back, hopefully the 2 fronts being bolted in should still be ok. Not fixing things that arent broke. Body lift makes sense if you are already in there but yes, considerations to cog are one.... The other - 1 inch? Really that much difference to warrant? I replaced shocks and springs a couple years ago thinking the clunking I was hearing was the bump stops. The additional lift was nice and that seems a better way to get more height if you are sagging. I cant see any benefit to lifting the body another inch? Thanks for the chimes on pulling up carpet, glad I asked and yall answered. Thank you so much!
2000 SR5 3.4L 4WD
ABS mod
11-11-2022, 01:30 PM
I'm using these... What needs greased? Couldn't find rubber bushings. :-(
9.4102G Universal Polyurethane Body Mounts Bushings Isolators, Include 4 Plated Metal Washers, 2 Plated Metal Sleeves, 4 Body Mount Bushings(Black) https://a.co/d/8fYL3hZ
2000 SR5 3.4L 4WD
ABS mod
11-11-2022, 01:36 PM
Old one. sorry it's rotated... turn your head to the left.
2000 SR5 3.4L 4WD
ABS mod
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
