Old 12-08-2022, 04:57 PM #16
Treestand_Twerkers Treestand_Twerkers is offline
Treestand_Twerkers is on a distinguished road
Originally Posted by brillo_76 View Post
Ah. Gotcha. Missed that part. I still put a meter on it and see how much it is drawing. That gives you an idea of what's going on. Then use @badluck method to track it down. If it still has issues after everything disconnected. Then it's a trace and fix wires project.
I'll do that.
what is the badluck method mentioned?
Treestand_Twerkers is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 12:42 PM #17
Update
8 broken wires or so at the rear door.
I'll update once I get those fixed.
can't upload pic, must be too big.
Old 12-09-2022, 12:52 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Back door. . ? Very interesting.
Old 12-12-2022, 12:31 PM #19
Tailgate wires broken
HOpefully fixing this resolves issue.
Either way, doing this fix on the other truck 2000 Limited.
ABS light on, Stuck in Park-tailgate_wires_broken-jpg
Old 12-12-2022, 02:43 PM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ah the rear door. I was thinking the rear side door. You are correct Toyota calls our hatch the rear door. That's extremely common. I had to fix a few wires there. The other common place I'd throw drivers door as well.
Old 01-03-2023, 12:34 PM #21
update
fixed all the wires and problem solved.
going to do the other truck just cuz.
needed 14g, 16, 18 and 20 gauge wires.
Tried the quick heat solder shrink wrap sleeves, on a couple, don't prefer them.
melting before solder melting..
So, conventional soldering.
TIP**
I have an alligator clip stand, and taped it to camera tripod in order to hold wires. worked well.
connector , pins , side , solenoid , switch
HELP! stuck in park! runnahmike 3rd gen T4Rs 18 03-01-2018 02:47 PM
Trans stuck in park fyrflie Classic T4Rs 2 07-05-2016 08:24 PM
Stuck in park pos... jeffmsunvalley 3rd gen T4Rs 5 09-14-2014 12:04 AM
4 Runner stuck in park T4Rscott 3rd gen T4Rs 5 03-28-2013 12:22 PM
tranny stuck in park tomcat 3rd gen T4Rs 8 03-01-2013 09:50 PM
