Old 11-21-2022, 10:49 PM #1
Mateo8's Avatar
Mateo8 Mateo8 is offline
Mateo8 is on a distinguished road
Mateo8's Avatar
Occasionally hard brake pedal
Recently when I have gone to drive my '97 4runner I have noticed that the brake pedal is rock hard when I go to start the car. It is a stick v6, I recently replaced the master and the slave cylinder to fix a weird feeling clutch. When driving the car, occasionally the pedal is hard (like when I go to start it) and braking performance is non-existent. I did blow out a rusty brake line in the summer, but it is full of fluid and there are no leaks under the car.
This is not a real "problem" for me as I do not need to go back into the office on a daily basis, but the day is soon coming when I need to go into the office everyday and cannot take the BMW as it is RHD and I need to access a gate on the way in and out of the parking garage. I have read some threads saying it is the booster as it is most likely the original and the 4Runner has 280k+ on it, I believe that to be the culprit. I have had success when I blip the throttle before I go to put in the clutch and then blip it when I start to brake, but that is a bandaid for a cut that requires stitches.
Does this match up to other owners experience, and if it does, which brand is recommended as a replacement?
Mateo8 is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 01:06 AM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
That is a sign of a brake booster that's going out. Check the integrity of the vacuum hose running from the intake plenum to the brake booster.
This video was done on a FJ80 Land Cruiser but it will give you an idea of how to handle the swap if your brake booster is bad.
t
Old 11-22-2022, 05:08 AM #3
For me the issue was the check valve in the booster.
Same exact symptom
Old 11-22-2022, 09:00 AM #4
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Had this problem when the weather was cold - it was also the check valve.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 11:58 AM #5
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I tried swapping the check valve on my hard brake pedal but that didn't resolve it, I ended up swapping the booster.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 02:16 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The only hard pedal I ever experience is very cold weather for like 2 to 5 seconds on startup. Then all is fine. So I expect vacuum lines, check valve or booster going so I agree with the others.
Old 11-22-2022, 04:36 PM #7
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Adding to the 'check valve' opinion from above. I had the exact same symptoms, on cold starts (at first, very cold) and gradually getting more frequent. The check valve is cheap and easy to replace, and my brakes worked 100% normally after. They just get sticky over time.
JohnMc is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 04:56 PM #8
cleanrunner's Avatar
cleanrunner cleanrunner is offline
cleanrunner is on a distinguished road
sounds like a booster.
Don't Text And Drive
cleanrunner is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 10:51 PM #9
Mateo8's Avatar
Mateo8's Avatar
I will watch the video right now, if it is the check valve, that sounds a lot easier and cheaper to replace. Hopefully that is the case, if not, I am mechanically inclined and should be able to get the problem solved in short order. Thank you everyone for the quick replies, I will let you know how it goes
brake , car , hard , pedal , start
Hard Brake Pedal on or off engine barely have brake when its drive from stop. makokak 3rd gen T4Rs 16 07-29-2021 10:32 PM
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 23 11-01-2019 04:15 PM
Brake pedal hard to push down shoota 3rd gen T4Rs 40 04-23-2019 09:26 PM
Hard Brake Pedal? Brake Accumulator? beatadrum 4th Gen T4Rs 2 02-17-2018 12:33 AM
Brake pedal hard to push? jarnld Classic T4Rs 5 05-14-2008 12:59 PM
