I decided to combine my various threads on Spiker Engineering products into one - this would serve as the place to highlight our products (current and new), as well as for Q&A and for announcements of sale events.
Spiker Engineering is a family run business - all of our items are designed right here in Southern California, and are fabricated in the US. We make a variety of products, which usually get their start from a need that is not well addressed by existing solutions. I personally design and engineer all of our products, and test them out in my truck before making them available for sale to the community (and usually ask willing volunteers to test them too, *cough*
JZiggy
*cough*). That way the products and the installation instructions are well vetted.
Ultimate Lift Hood Struts.
Our first product, and still our best seller, is the Ultimate Lift hood strut kit. It allows you to pop the hood and have it open effortlessly to a height of up to 8" above stock height. You'll appreciate the extra lighting and access that comes with the extra height, all without the prop rod in your way. To answer a common question, the hood struts do not have to be set to the maximum height - any position between stock prop rod height and up to 8" higher can be accommodated.
The kit includes all components needed for installation: enameled premium gas springs sized for the 4Runner's hood weight and geometry; gloss black mounting brackets; ball studs and Belleville washers; and heavy duty multigrip rivets that can accommodate even oversized holes without the need for a backup washer. Also included is a drill bit stopper to control the drilling depth, and illustrated step by step installation instructions.
You can read more about the hood strut kits and order them
here.
Our hood strut kit is also available on
Amazon.
Ultragauge/Scangauge Mounts.
Next is a set of mounts that securely hold the Ultragauge, Scangauge II, and the recently released Scangauge III. These mounts are made from 14 ga steel, and powder coated in matte black. They attach to the a-pillar grab handle, and are designed to place the gauges directly in your line of sight without obstructing your view of the road.
Ultragauge Mount:
Scangauge II Mount:
Scangauge III Mount:
We also have an add-on gauge holder for these mounts for standard 2-1/16" gauges - trans temp, boost, etc:
You can read more about these mounts and order them
here.
Phone Mounts.
Our phone mount attaches to the dash just above the center bezel, placing the phone where you can easily see and reach it, without obstructing your view of the road, the AC vents, or the clock.
The mount is made from 14 ga steel, powder coated in matte black. It is custom shaped to closely fit the curved dash surfaces, and attaches to the dash with pre-adhered pads of 3M VHB LSE tape. We also include two optional push pins to fully lock the mount to the dash. With the push pins installed, the mount will hold up to most any kind of wheeling you have in mind!
The actual phone mounting surface can accept a wide variety of phone holders, from magnets to any holder that works with the rectangular AMPS pattern, like the Panavise, RAM, and similar phone holders. Most of these options are available from our website (we're an authorized Panavise and RAM dealer, so these products are guaranteed to be legit).
Magnet Mount:
Panavise Mount:
RAM X-Grip Mount:
You can read more about the mounts and order them
here.
Scangauge & Gauge Mount Bundles.
We recently added discounted bundle pricing for purchases of our gauge mounts together with the Scangauge II or Scangauge III. You can save $20 off the mount price when bundling with the Scangauge.
We're an authorized Scangauge dealer, so you will be getting factory packed Scangauges with your purchase, guaranteed to be genuine.
The bundles are available
here.
Thanks for reading and happy browsing!
