Old 11-26-2022, 09:25 PM #1
405Runner's Avatar
405Runner 405Runner is offline
405Runner is on a distinguished road
405Runner's Avatar
Center Diff Lock Switch Question
Hey there.
Took the 405Runner out today and was trying to get the center diff to lock. But no luck. I remember it working awhile back, but we haven't had much bad weather lately so never messed with it.
The light works, since it blinks when the 4WD is engaging.
So, I pulled the switch, and I don't have any continuity between any of the points when its neutral, or when I push it down. So I'm just thinking it's a bad switch. Looked all over the FSM but can't find a pin out for it or a test. Just wanted to see what others thought.
Edit: Guess I remembered wrong. I havent done anything under the dash other than a new ignition switch. So, guess I just remember the yellow ball blinking.
2001 4Runner SR5 4x4
Trans - Auto, Stock //Engine - GM 140A alt//Suspension - Stock.//Wheels - Toyota 16" Steelies//Tires - 265/70R Falken Wildpeak AT3W
Other -AMP'd UP Hidden Winch Mount, Badlands 12k winch, VSC/TRAC mod
405Runner is offline   Reply With QuoteReply With Quote
Old 11-27-2022, 10:32 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by 405Runner View Post
Hey there.
When you say switch are you talking about the button you push or one of the sensor switches on the transfer case/front diff?
Old 11-27-2022, 10:50 AM #3
405Runner's Avatar
405Runner's Avatar
Push button switch.
Old 11-27-2022, 05:49 PM #4
405Runner's Avatar
405Runner's Avatar
Figured it out.
PO must have been in there messing around. There are 2 plugs that fit the switch. Finally sat down and found the switch in the wiring diagram and it said only a grey/white-black wire ran to it, the plug that was inserted had 4 wires, and it only had the white-blk wire. So, Plugged in the correct one, and bam-o works.
bad , center , diff , lock , switch
Locked 4wd on dry pavement - Center diff lock as VSC OFF switch JB. 4th Gen T4Rs 13 07-11-2022 01:32 AM
Center diff lock question. Jesman 4th Gen T4Rs 16 01-04-2015 02:22 AM
Center diff lock switch jreask 3rd gen T4Rs 10 11-28-2013 10:44 AM
Removing the Center Diff Lock Switch Javelin 4th Gen T4Rs 12 06-17-2012 09:29 AM
Center Diff Lock Switch... mtskibum16 Problems & Warranty Issues 0 03-26-2008 09:34 PM
