Old 11-26-2022, 10:50 PM #1
nissanh nissanh is offline
How can you avoid burning clutches in an Auto Transmission
Rocket Rod in Australia has posted a video of a tear down of a Land Cruiser 200 series transmission.
Watch from 26 minute:
https://www.youtube.com/watch?v=BFyZJLE-aIk
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 11-27-2022, 12:14 AM #2
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
great video overall, subscribed. Most people don't know the reason of 4 low, because you can almost do the same in hi range pressing more on the gas. Low range is to save your transmission and many other things. Use it.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 11-27-2022, 11:16 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Great info - thanks for posting. Overall its still about avoiding High trans fluid temps.
So besides proper OCI (is 30K the general consensus for a drain/fill?), using OD override when climbing hills/mountain passes and/or towing, perhaps using auxiliary cooling, we also need to remember to use Lo on slow steep climbs, slow yet steady maneuvers and such. I don't do much of the last, yet will use Lo more often from now on.
Also on the 01-02s you can start in 2nd gear to avoid the 1-2 shift jolt if you're planning on going that 'fast'. Luck all.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 11-27-2022, 12:06 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Man, that video could have been so much better if the camera work didn't suck. I was interested in seeing how the transmission came apart but the crazy camera angles ruined it and I couldn't watch it.
But yeah, the thing to take away is heat is the killer of automatic transmissions. I preach this to everyone I go 4wheeling with to the point jokes are made about "Hot Trannies".
Anyway, I have two videos I've made on this subject matter.
t
Old 11-27-2022, 12:16 PM #5
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I think a drain and refill every 30k is insufficient. You're only draining out a 1/3 of the capacity, around 4-4.5 quarts of a 12 quart system. This means you're exchanging out 12 quarts every 90k miles.
I do a drain and refill of the pan every other engine oil change or approximately every 10k miles. Why? Because with the way I drive my rig, and with how heavy it is, I'm running higher temps even with a decent size trans cooler. As the temperature of the fluid goes up, the effective life of the fluid goes down. I want to give my trans the best chance at a long life and doing regular drain and refills is the best insurance to achieve that.
If you drive the flat lands for the most part using your rig as a grocery-getter, your trans fluid could last you 100k miles. For anyone who drives a lot in the mountains and/or goes 4wheeling, your trans fluid is not going to last anywhere near 100k, more like 15-30k.
Drain and refills are a dilution process, but it's a very effective way to keep your trans fluid in great shape. I'd rather do regular drain and refills than wait a longer interval and do a full flush/exchange.
Old 11-27-2022, 12:53 PM #6
I always thought burned clutch packs was a product of not enough line pressure for the job at hand. Hot thin oil would lower line pressure……
Old 11-28-2022, 12:21 AM #7
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
I imagine towing in OD would be a great way to burn up a clutch. Assuming it's like a 4L60E.
Towing is always tough on a vehicle, but looking after the transmission temps is a good idea
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
cruiser , minute , series , transmission , watch
Lets Talk Clutches Chazzmatazz Classic T4Rs 3 09-06-2019 01:48 PM
97 auto to 99 auto transmission swap thegipper 3rd gen T4Rs 17 05-23-2017 05:13 PM
Yahoo Auto Article - 5 Used Cars to Avoid TheSentinel General Discussions 4 07-25-2011 12:10 AM
Burning grease / Burning rubber smell? Cape 4RUNNER 4th Gen T4Rs 3 01-04-2010 12:39 AM
