11-29-2022, 02:19 PM
Sticky Steering
So lately, I've noticed my steering is a bit sticky. When I take a corner it's harder to return the wheel to center. My steering rack was replaced about 2 years ago as well as my steering pump and reservoir. All OEM. These weren't done to address this problem. It was just time.
The only thing I can think of is a low tire tread. hence more tire on the ground as I turn. But that's just a hunch. Tie rods are a few years old as well but definitely on the newer side. Wondering what else it could be. Any ideas?
Thanks!!
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
11-29-2022, 06:28 PM
Real Name: Patrick
Real Name: Patrick
Thanks!!
Is this while driving or while stopped?
11-29-2022, 06:39 PM
while driving.
Manual Transmission
11-29-2022, 11:20 PM
Real Name: Tim
Real Name: Tim
Check your power steering fluid level.
11-30-2022, 01:00 AM
Real Name: Dave
Real Name: Dave
Did you find the problem?
11-30-2022, 03:28 AM
You need to lift the front tires off the ground, both at once, and turn the steering
wheel full left and right with the engine off and see if it turns freely or binds.
You could have a bad ball joint or tie rod end or anything in the steering system.
If nothing is binding you may need an alignment.
2000 4Runner Limited w/TRD Supercharger
And E-Locker
11-30-2022, 08:02 AM
Check your Intermediate Steering Shaft. The universal joints in it corrode over time and start to bind up. This generally presents itself as a loose - tight - loose - tight feel as you turn the wheel. Sometimes you can coax a little more life out of one with lots of penetrating oil followed by Fluid Film.
11-30-2022, 12:06 PM
The 3rd Gen 4Runners Steering shaft U-joint is located inside the cab and don't rot out like the 4th gen 4R and 2nd Gen Taco that have the steering shaft located beside the wheel well. Maybe check the rack guide tension, and body mounts.
11-30-2022, 03:13 PM
Thank you for the correction! I didn't see that he's in a 3rd gen until after I posted. The Intermediate Steering Shaft is a big issue in 2nd and 3rd gen Tacomas and 4th and 5th gen 4Runners. Ask me how I know that.
12-02-2022, 12:05 AM
fluid level is perfect and the fluid looks good in general. not an ounce of rust underneath. grateful for az weather. I'll lift the front and see if anything is off. im stumped. it feels like when i make a turn, the edge of the tire is catching and it fights me to return to center. just not all the time.
remember when youd ride a bicycle and turn the handlebars to much and you went over the wheels/crashed? it's kind of oddly like that.
Manual Transmission
12-02-2022, 12:12 AM
Real Name: Charlie
Real Name: Charlie
Could possibly be a worn out or jammed up steering rack guide? I know when I have adjusted mine too tight before, the steering has gotten kind of notchy like you describe. Maybe try taking it apart, cleaning, and greasing it.
Originally Posted by STX4Runner
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
12-02-2022, 12:23 AM
Id go have the alignment checked. Not enough Caster can cause this and if there is anything else wrong or worn they will find it.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
12-02-2022, 07:22 AM
i might be the only guy who buys a lifetime alignment when the truck reached 210k mi lol. I'll go get it checked.
not sure what the steering rack guide is though. will need to learn more about it.
thanks for all the input guys.
Manual Transmission
12-02-2022, 08:15 AM
Real Name: Charlie
Real Name: Charlie
Here's a write-up on upgrading to the newer style guide (which your replacement rack should have already) but it shows the process with photos.
How to: Replace steering rack guide- Pictures
Pretty much mark the current position with a paint pen or sharpie, then take channel locks or an adjustable wrench to loosen the big nut and it'll come out. Clean and grease it.
Then reassemble (need a big allen wrench or threaded rod connector for the inner part) and play with the adjustment but still have the original one marked to go back to if you can't make it any better.
12-02-2022, 10:09 AM
hmm. my rack is nearly brand new oem. maybe 10k mi on it.
thx for posting the link. if i cant find another problem, I'll investigate this more.
Manual Transmission
