Old 11-30-2022, 05:55 PM #1
Paulmaz's Avatar
Paulmaz Paulmaz is offline
Paulmaz is on a distinguished road
Paulmaz's Avatar
2002 4R tire size 265/70 R16, how size tires?
HI there-
this may be a dumb question, but here we go. My son has a 2002 4R with size tires 265/70 R16. It has the standard silver wheels, and he wants black ones. I am trying to search for them, and do not understand sizing. For example, I found these:
BLACK | 15X8 | 6X5.5 | 4.25 BORE | -19
what do these sizes mean? How does that correlate to the tire size?
Other questions...anyone recommend a reasonable set of black wheels? Most i find cost between $85-$250 each. Also, right now, the tires are basic Good years, and have less than a year left. We will be upgrading these to some good all terrains too.
TIA,
Paul
2002 4Runner 2WD
292K miles and counting!
Some Pics
Paulmaz is offline   Reply With QuoteReply With Quote
Old 11-30-2022, 06:23 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Paulmaz View Post
HI there-
TIA,
Paul
Those are 15 inches in diameter (corresponds to the number after the "R" in the tire size), 8 inches wide.
6x5.5 is the same as 6x139.7 which is the correct bolt pattern.
4.25 inch bore is about 108 mm. You need 106 mm bore for it to be hubcentric.
-19 is the offset. Here's an explanation of offset:https://www.tirerack.com/tires/tiret...jsp?techid=101
Unless you have a base model 4Runner (not an SR5 or Limited) then most 15 inch wheels will not work. You will need 16 inch wheels or larger. Factory wheel size is 16x7.
Old 11-30-2022, 06:31 PM #3
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
HI there-
Other questions...anyone recommend a reasonable set of black wheels? Most i find cost between $85-$250 each. Also, right now, the tires are basic Good years, and have less than a year left. We will be upgrading these to some good all terrains too. I know the peelable aerosol has its detractors, but it has held up on my wheels for a few years.
TIA,
Paul
If it was my kid, I'd hand him 2 cans of satin black paint and tell him to get after it. You could get him a Plasti-dip kit if you are shooting for Dad of the Year award.
Old 11-30-2022, 06:34 PM #4
Paulmaz's Avatar
Paulmaz's Avatar
Thank you for the explanation! How do I know how wide to get? Looks like doing a search for 16 inch with 6X5.5 brings back mostly 8 or 10 inch wide.
2002 4Runner 2WD
Some Pics
Old 11-30-2022, 06:39 PM #5
Paulmaz's Avatar
Paulmaz's Avatar
I thought about this...this stuff looks pretty good! I guess you would take wheel off to do it? Or do you do it with it on the car?
2002 4Runner 2WD
Some Pics
Old 11-30-2022, 09:08 PM #6
Real Name: Blair
Real Name: Blair
You can do it wheel-on. The kit has bags to cover the disc and calipers. You spray some stuff they provide on the rubber so the dip doesn't adhere. It's stupid-easy and provides fairly instant gratification. Looks decent on the 5-star alu wheels on my 2000. Might be fun to do with your son. Many colors besides black, too. They SAY it's easy to peel off if you change your mind but I've heard it can be a bit tedious.
OK sales pitch over - I'm not saying it as nice as a good set of wheels but it does the job and has held up for me.
Old 02-20-2023, 06:31 PM #7
Paulmaz's Avatar
Paulmaz's Avatar
Used Hyper Dip
Just wanted to follow up on this. we ended up getting the Hyper Dip from DipYourCar.com, and did the wheels and the rear emblems. Check out my album below (Some Pics) it was really easy, and looks great. We ended up taking the wheels off to do it. We will see how long it lasts!
2002 4Runner 2WD
Some Pics
black , good , size , tires , wheels
Tire size on door sticker vs. actual tires... One Sick Puppy 3rd gen T4Rs 12 07-07-2014 12:56 PM
Best AT for winter driving, and what tire size from the 2011 tires 4runner Stig 4th Gen T4Rs 11 10-07-2011 02:01 AM
What tire pressure do you run in your stock size tires??? Jeff T 4th Gen T4Rs 2 07-27-2011 08:00 AM
2002 4runner tire size Waldo General Discussions 1 08-31-2010 02:05 AM
2002 4Runner, what size tires? Master Yoder 3rd gen T4Rs 2 10-07-2009 08:09 PM
