Old 11-30-2022, 09:25 PM #1
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin will become famous soon enough
So so road manners
I think I've got a good idea of whats going on but figured I would float this by the forum. Truck drives great on good roads up to about 65. Past that it feels like it's wanting to randomly pull one side or the other (wandering steering I guess you could call it?). Especially noticeable in the right lane on I-70 Westbound going into the mountains where there seems to be some small rutts. If it's an extremely well paved road I don't experience this which leads me away from slop in the rack and alignment (also no noticeable irregular tread wear that I can tell). Also kind of jerky at lower speed when I hit potholes. I'm thinking this is a combo of steering rack bushings, sway bar bushings and possibly even body mounts making it harsher (they don't look terrible but I guarantee they are 25 years old). Also possibly something to do with stock panhard on a 2" spacer lift, the spacer lift itself and the stock rear sway bar end links. Does it sound like I'm barking up the right tree? Are sway bar and rack bushings probably going to be my best bet to tackle first (I like this idea since it's byfar the cheapest thing to tackle first) maybe also finding OEM front endlinks to put on the rear while I'm at it?
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 11-30-2022, 10:14 PM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid will become famous soon enough Twisted Sid will become famous soon enough
I'd say rack bushings and control arm bushings are more likely than the sway bar and panhard bushings and body mounts.
94 pickup: 2wd, 22RE, 5spd,
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover Shocks,
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, TRD E-locker Axle 4.88 Gears
33x10.5 BFG ATs
99 4Runner SR5: 5VZ, 2wd Stock (for now) Daily driver
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 11-30-2022, 11:13 PM #3
Bleh your right I forgot about control arm bushings. That's a job that looks rather involved. Also I was talking more about not having the panhard brackets to correct geometry.
'98 SR5 5 Speed
Old 11-30-2022, 11:18 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Panhard bar geometry is not likely your issue. Wandering/drifting is more likely control arm bushings/steering rack bushings. Sway bar bushings have no effect on steering issues.
Old 12-01-2022, 11:21 AM #5
jross20's Avatar
jross20 jross20 is offline
jross20 has a spectacular aura about jross20 has a spectacular aura about jross20 has a spectacular aura about
jross20's Avatar
If you end up needing to change the front lower control arm bushings I would honestly just replace the arms with oem. Just my two cents
bar , bushings , noticeable , rack , sway
4runner Limited horrible onroad manners Helixx 5th gen T4Rs 19 06-29-2020 01:36 AM
Off road manners your mom would be proud of RagoFabrication Rago Fabrication 0 03-27-2019 10:22 AM
Rate your truck's highway manners 4Runner4Leon 3rd gen T4Rs 88 01-21-2018 07:37 AM
Highway Manners & Custom Order bt72 5th gen T4Rs 13 03-07-2010 10:09 PM
Courtesy and Decent Manners jpalaska 4th Gen T4Rs 64 03-06-2009 06:08 PM
