Old 12-04-2022, 12:20 PM #1
ultimatt ultimatt is offline
ultimatt is on a distinguished road
Power Steering loud whine on startup
So my power steering has started screaming on cold startup. It dies down after about 30 secs to a minute depending on how cold it is outside. I checked the PS fluid level and when it started it was down a bit but not below what was acceptable.
So my question is...I would assume the pump is going bad. If that is the consensus how hard of a job is it to replace? Also, is this a fix right now situation or can I simply deal with the whine until I get good and ready to fix it?
Thanks.
ultimatt is offline   Reply With QuoteReply With Quote
Old 12-04-2022, 12:53 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I think you should check to see if your reservoir screen needs a good cleaning before replacing the pump. A dirty screen prevents optimum flow of fluid from the pump to the steering rack and back. When the fluid is cold, it's thicker, which will restrict fluid flow until it warms up a bit. A clogged screen along with cold fluid is probably why your pump is making noise.
Clean the screen and do a flush of the fluid and see where that gets you.
I have a video for the process.
Old 12-04-2022, 07:51 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I agree with Tim, clean the reservoir screen, flush the system and refill it with fresh Dexron III ATF. That being said, I had what I though was the same exact cold start power steering whine, but I noticed that it didn't change if I turned the steering wheel. Turned out it was the alternator bearing starting to fail.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 05:54 PM #4
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Plus 3
Your screen in the bottom of the your power steering reservoir is most likely clogging up. So I would start there. If you flush the PS system and the screen is clean and it still whines. That's another issue. :-(
I would get the new replacement o ring before pulling that reservoir off or you run the chance of creating a power steering leak at that point. I made that mistake once.. Now I keep a spare or 2 o ring on inventory so I don't have that issue never again.
brillo_76 is online now   Reply With QuoteReply With Quote
cold , fix , power , started , steering
Power steering(?) whine only on startup JH225 4th Gen T4Rs 8 01-22-2021 04:54 PM
Power Steering Whine FrothyLlama 4th Gen T4Rs 15 10-11-2020 03:02 PM
Power Steering Whine Cire2 5th gen T4Rs 9 03-23-2016 12:26 AM
Power Steering whine Brian1973 3rd gen T4Rs 4 11-05-2014 07:40 PM
