Old 12-05-2022, 12:28 AM #1
aa010175's Avatar
aa010175 aa010175 is offline
Real Name: Dave
aa010175 is on a distinguished road
aa010175's Avatar
Real Name: Dave
Ruff ride and need a fix.
My 2000 4x4 SR5 rides like a semi truck. I talked to a lady that has a 2000 2 wheel drive and she said hers has a very nice ride. Could that be true? And if so can I swap out 2 wheel drive springs (front and rear) for mine? I use mine for road travel only. I have new Monroe strut #71351 and rear is Monroe #37157 for the rear. Will the springs of a 2 wheel drive fit a 4x4? I believe the the springs don’t have enough give. This is a paved road only vehicle. Thanks Dave
aa010175 is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 01:02 AM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Originally Posted by aa010175 View Post
My 2000 4x4 SR5 rides like a semi truck. I talked to a lady that has a 2000 2 wheel drive and she said hers has a very nice ride. Could that be true? And if so can I swap out 2 wheel drive springs (front and rear) for mine? I use mine for road travel only. Thanks Dave
as far as I'm aware, there's no difference in springs between 4wd and 2wd, maybe her springs/shocks are newer or they're aftermarket, could be a lot of factors to it
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 08:00 AM #3
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
The softest ride your gonna get is gonna be from all OEM shocks and springs,anything aftermarket is going to be stiffer at least in my experience. A “very nice ride” is also very subjective. I happen to like how my 4Runner rides but my friends feel like they are riding the space shuttle Columbia. Make sure your bushings are in good shape as well
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 12:34 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
2wd springs are softer and will cause lower ride height if used on a 4wd.
Old 12-05-2022, 12:38 PM #5
Real Name: Patrick
Real Name: Patrick
If you want an OEM ride you have to use OEM shocks. Anything aftermarket is not going to ride as well at the same ride height. Your ride quality is likely due to the monroe shocks and not the springs. If you use 2wd springs your ride height will be lower than designed/intended and you will bottom out easier on bumps.
Get OEM 99 tall springs for a 4wd front and rear and OEM shocks. Also, keep in mind that tires and tire pressure play a key role in ride quality. If you have LT tires and/or run your tire pressure high then your ride quality is going to suck regardless of the suspension components.
Old 12-06-2022, 12:29 AM #6
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
Thanks for the detailed response! The ride is ruff and with stiffness. It was bad before I replaced the shocks and replacing the shocks didn’t change the bad ride unfortunately. I think the springs need to be softer. Dave
Old 12-06-2022, 02:39 AM #7
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
These things are body on frame construction and are 20+ years old and will never ride like a new car.
With that said, do what Bad Luck said and if you are still on the original springs, change them out for the '99 talls and put on some better shocks. Sagged out tired springs will ride like crap and bottom out and putting softer springs on it will make it way worse.
Monroe shocks are low end at best and will not dampen very well.
Put some OEM Tokicos or KYBs and it might ride like a 10 year old truck
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 12-06-2022, 10:26 AM #8
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
When I did a refresh on my 02 @180K as it was still riding on it’s original suspension.
I went with new factory springs all around and KYB shocks/struts as I was looking for a comfortable factory ride for daily highway use.
30K miles later and I’m still very happy with the ride/handling.
In time I also replaced most all suspension bushings which helped as well.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
drive , mine , ride , swap , wheel
ruff ride minerdoug 3rd gen T4Rs 10 05-09-2014 07:30 PM
ruff ride conchbuggy17 3rd gen T4Rs 6 09-10-2012 07:47 AM
99 running ruff mynewtoy 3rd gen T4Rs 7 01-23-2011 03:04 PM
Ruff Rider Landman 3rd gen T4Rs 1 05-09-2008 01:14 PM
Will beg for carfax help... ruff ruff. :-) rensho Off Topic 1 01-04-2006 01:26 AM
