Old 12-05-2022, 07:38 PM #1
CoCoCo4Runner CoCoCo4Runner is offline
CoCoCo4Runner is on a distinguished road
1998 4Runner Small Mods
Hello all. I finally got my 1998 Limited on the road again, replacement engine completely resealed and it's running very well. First engine swap I ever did on my own, and surprisingly it just worked when I was done, nothing major to fix that I can see after a few days of driving. I also have a set of LBJ I am planning to install before doing any major trips or wheeling it.
Now that the hard work is done, I can focus on the fun stuff, modding. One thing I noticed right off the bat is that the rear suspension is tired and needs to be addressed. All four corners sit about 35" off the ground empty (measured at the center cap and from the floor to the edge of the wheelwell) but when loaded up the rear end squats very notably. The PO replaced the front end with some OEM spec Bilstein suspension so I'd prefer to keep that as is. I've heard good things about OME springs and Bilstein shock combo, what is the preferred spring if I want a good mix of capability and livability, leaning toward capability (I don't really care if it rides somewhat rough unloaded, it's a truck).
Another consideration, it currently has some street friendly 265/70 r16 tires and I am highly interested in upgrading to some A/T 265/75 r16 that can clear Tundra brakes down the line. Will there be any fitment issues with 32" wheels and stock ride height?
Thanks all!
1998 4Runner Small Mods-img_1749-jpg
CoCoCo4Runner is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 07:52 PM #2
that3rdgen that3rdgen is offline
that3rdgen is on a distinguished road
it will rub in the front rears should clear but you will probably scrub at full lock at least i do. but definetly still drivable. i offroad mine a decnt amount and have issues with the bumper scrubbing before the tires do.
1996 SR5 4Runner "Felipe"
1996 SR5 4Runner "Felipe Jr"
1997 Sr5 4Runner 2WD
@felipe_t4r on insta
that3rdgen is offline   Reply With QuoteReply With Quote
Old 12-06-2022, 11:48 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks all!
906 or 890 springs for the rear. Some people find the 906 springs to be a little harsh when unloaded and they provide 1.5-2" of lift in the rear over factory. 890 springs will be softer but you will get 2-3" of lift in the rear over factory with stock weight.
Tire size does not affect brake caliper clearance, only wheel size/design does. The current wheels you have will clear the 199mm Tundra brakes but will not clear the 231mm Tundra brakes.
I have 265/70R17 tires which are the equivalent of 265/75R16 tires and will only rub if turned and flexing. You might not rub at all depending on your ride height which looks a little higher than factory. OEM hub to fender height is 20 inches. Hub to fender measurement is easier to compare because it takes the tire size out of the equation.
Old 12-07-2022, 01:30 PM #4
Originally Posted by Bad Luck View Post
I have 265/70R17 tires which are the equivalent of 265/75R16 tires and will only rub if turned and flexing. You might not rub at all depending on your ride height which looks a little higher than factory. OEM hub to fender height is 22 inches. Hub to fender measurement is easier to compare because it takes the tire size out of the equation.
Quick correction - OEM ride height is 20" not 22" for comparison sake. '99's will be a bit higher, others right at or lower than 20" The OEM rear springs are quite soft...
265/70-17 or 265/75-16 (same rolling diameter, etc.) will fit on a stock height 4Runner, but you do have to make sure the alignment is done correctly. You need 'max caster' which pushes the wheels farther forward in the wheel well to clear the wheel well liner. Here is where it rubs if you don't:
(the inner plastic fender liner is a bit 'darker' where the tire was rubbing)
That's with 265/70-17 AT's at stock height and original alignment.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-07-2022, 03:58 PM #5
Real Name: Patrick
Real Name: Patrick
Thanks for the correction! Original post edited.
Old 12-07-2022, 11:49 PM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Were you the one complaining in some thread last week about how difficult the swap was for you? If so congrats on seeing it through!
Old 12-09-2022, 08:28 PM #7
Yeah that may have been me haha! Unfortunately it's not running as well as I'd hope, running very rich with a high idle. Trying to chase down vacuum leaks to see if that's the cause.
Old 12-10-2022, 10:49 AM #8
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
What symptoms make you think it's rich? Not disagreeing just curious for my own knowledge... Haha
Old 12-10-2022, 01:28 PM #9
Exhaust smells gassy, visible smoke when cold
end , major , rear , suspension , wheels
Do small mods void warranty? Trd skid plate, fogs, headlights, raptor lights etc? ErnieArt 5th gen T4Rs 26 05-24-2022 09:56 AM
Choice of 2d battery for camperised Chilean 05 4Runner - small Amp or engine mods agua.fresca.viaje 4th Gen T4Rs 3 07-29-2020 03:34 PM
FS: 1998 Toyota 4Runner Limited (e-locker / mods++) APhelps For Sale: Vehicles 5 07-24-2020 06:29 PM
FS: 1998 Toyota 4Runner Limited (e-locker / mods++) APhelps For Sale: Vehicles 0 07-14-2020 10:28 PM
