Old 12-05-2022, 08:29 PM #1
psea17 psea17 is offline
psea17 will become famous soon enough
Tie Rod End Bushing/Boot?
does anyone know if the boot/bushing that resides where the tie rod meets the LBJ is replaceable? trying to find a part number.
or does this require a new tie rod end?
having the same problem w/ the lbj boot. appears the only option is to replace the entire LBJ rather than reboot. there's apparently a landcruiser boot (OEM P/N 43345-69025) that might work but i've yet to find a post installation update.
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 08:36 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If the lbj boot fails you replace the lbj. If the tie rod end boot fails you replace the tie rod end. The only thing I know that gets rebooted are cv joints as far as I know.
Old 12-05-2022, 08:49 PM #3
i know you can reboot (oem) upper ball joints. that's why i was a bit surprised. (cv joints and inner tie rods too iirc).
thanks!
Manual Transmission
Old 12-05-2022, 08:56 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It's a good thought. Mostly when those boots fail water can get in. If that happens you really want to just replace them. Especially that lower ball joint being with the design of them they can easily fail. The maximum play in that lower ball joint us.( .5mm ) We can't see that amount.
I know if my upper boot cracks and leaks.. I am changing my upper ball joint. I will not reboot it.
Old 12-05-2022, 09:19 PM #5
Zhehan Zhehan is offline
Zhehan has a spectacular aura about Zhehan has a spectacular aura about
Brillo, you mean 0.5 mm, right? 5mm ~ 1/5 of an inch, which you would definitely notice.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 09:33 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes it's .5mm. If you have 5mm you no longer have a ball joint. They pull apart way before that. I suspect it will pull apart at 1mm or less. Thanks for the correction. I put it in () so it's more clear..
Old 12-05-2022, 09:35 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tim even has a video on how to properly check those Lower ball joints. I checked mine and I am still within spec..
boot , find , lbj , rod , tie
Inner CV boot split at edge, can someone suggest a split boot repair kit? sakoluvr 3rd gen T4Rs 7 10-17-2018 02:55 PM
Front diff mount bushing and Rear UCA bushing PN? bugman-74 3rd gen T4Rs 12 01-07-2018 09:49 AM
Upper ball joint boot leakóreplace UBJs or just boot kit? starclassic 3rd gen T4Rs 4 07-31-2016 02:50 AM
Sway bar bushing is dry/torn boot/link kit pj2006 4th Gen T4Rs 7 06-15-2014 02:00 PM
Rear shocks: boot up or boot down? mrlouie 3rd gen T4Rs 4 08-22-2011 10:27 AM
