Old 12-07-2022, 05:16 PM #1
Alan in Alabama Alan in Alabama is offline
Alan in Alabama is on a distinguished road
Denso ignition cable resistance
I ordered a set of Denso ignition cables for a 1999 3.4 V6 from Amazon. Denso 671-6182. Before installation I measured the cables' resistance. 1.6 kOhms, 1.6 kOhms, and 61 kOhms. One cable way out of spec. I returned them to Amazon. Then I ordered the same set from Rock Auto. They tested 1.6 kOhms, 1.6 kOhms, and 18 kOhms. Again, one cable way, way more than the other two.
Did both sets have one defective wire?
Are the wire sets designed to have one wire with much greater resistance?
Has anyone else measured their cables before installation?
By coincidence, or maybe not, the longest of the three cables in each set was the one with the much higher resistance, although the longest one in each set was longer by only a few inches than the others. I tested with two different VOM's. Same resistance values.
Alan in Alabama is offline   Reply With QuoteReply With Quote
Old 12-07-2022, 05:30 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Try installing them and see what happens. I've never measured the resistance of the spark plug wires, but I also don't go searching for problems before they exist.
Old 12-07-2022, 05:56 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My signature has a link to the thread on spark plug wire resistance measurements.
Old 12-07-2022, 06:22 PM #4
Real Name: Patrick
Real Name: Patrick
Your spark plug info link takes me to the main forum page. You need to add an "l" at the end of your signature link. That's a lower case "L" by the way.
Old 12-07-2022, 06:42 PM #5
From this thread in another forum...
Spark plug wire resistance | Toyota 4Runner Forum [4Runners.com]
I deduced that the Denso cables have lower resistance than other brands. That's why I picked this brand of cable. And two of the three cables in each set do indeed have less than 2000 Ohms resistance. The third cable way more.
The cables in the car now are some AutoZone cables the previous owner installed and they are around 15000 Ohms and the engine runs fine.
Toyota specifies less than 25000 Ohms.
Still the mystery is why 2 of 3 are low resistance and one high resistance in each set I measured. On purpose? Quality control problem?
Brillo 76: I couldn't find the link you referred to. It goes to a menu of many items. Could you narrow it down?
For now I'll keep the AutoZone cables it's using. "If it works, don't fix it."
Old 12-07-2022, 07:20 PM #6
My "conspiracy theory".
* The Denso cables limit radio interference by shielding a rather low resistance inner wire. Most cables limit radio interference by using high resistance graphite to carry a much smaller non radio interfering current.
* The Toyota computer may set a code if it sees too low a resistance in the ignition system. Denso realized this after manufacturing a bunch of cable sets. Rather than junking them all, they replaced one of the cables in each set with a high resistance conventional cable and it worked ok with only 2 of 3 high-tech cables. No one would ever check cable resistances if the car ran ok after installation.
Or maybe due to poor quality control 1/3 of the cables were bad. And by chance each set had 2 good cables and 1 high resistance cable.
Old 12-07-2022, 08:38 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Fixed it..
Old 12-07-2022, 08:41 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
We had a good discussion on that thread. The core of the spark plug wires that make the difference.
I fixed it.. Somehow my l was missing off the .html hence why it was messed up.
Old 12-07-2022, 08:44 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I like your theory. The mfg of the Toyota wires are made by Sumitomos at least back in the day they were. Might still be not 100% sure on if new oems are still Sumitomos.
Old 12-07-2022, 09:28 PM #10
brillo 76... The new link works perfect. And the picture with where the cables go is very helpful.
Alan
Old 12-07-2022, 09:34 PM #11
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Use the Sumitomo OEM wires with date of manufacturing on it, they fit the plug wells and coils way better than aftermarket, when I changed my wires last year which said 1998 (24 years old) on them and still working perfectly fine, I installed the same Sumitomo OEM wires with the date 2022, truck ran exactly the same.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 12-07-2022, 10:27 PM #12
I use the mag core wires sets. Been using them since the late 80’s
They are less than 1k ohm per foot. I am currently using car quest because their resistance was half the ones from AUtoZone.
Old 12-07-2022, 10:30 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sweet glad to hear the sumitomo wires are still an option.
Old 12-08-2022, 12:36 AM #14
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
They were unavailable in the US for many years. The dealers only had Densos. That changed maybe ten years ago. I have to say I have ten years and 120K on my blue NGKs and the rig runs perfectly.
My Backyard Frame Swap
Old 12-08-2022, 06:34 AM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am running blue NGKs as well. I just like folks to have a few options.
The magcore wires would be a good choice as well as they are lower resistance ones.
cables , kohms , resistance , set , wire
Ignition refresh: going Denso this time octanejunkie 3rd gen T4Rs 15 02-12-2022 07:42 PM
2000 4runner a340f kickdown cable (tv cable) broken DPR64 3rd gen T4Rs 3 09-07-2021 02:28 PM
throttle valve cable/transmission kickdown cable stuck roll4life 3rd gen T4Rs 4 08-16-2016 02:03 PM
New ignition lock cylinder - won't engage ignition - 1996 base CanadaEh 3rd gen T4Rs 2 07-26-2016 03:18 PM
Spare tire cable bad, replace cable or carier? iBison 4th Gen T4Rs 10 06-16-2014 11:10 AM
