Old 12-09-2022, 04:17 AM #16
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Yes the OEM Sumitomo wires are indeed available in Canada at Toyota, so I'm sure they are in the US. The NGK do not fit as well as the OEM IMO after installing each.
Malcolm99 is offline   Reply With QuoteReply With Quote
cables , kohms , resistance , set , wire
Ignition refresh: going Denso this time octanejunkie 3rd gen T4Rs 15 02-12-2022 07:42 PM
2000 4runner a340f kickdown cable (tv cable) broken DPR64 3rd gen T4Rs 3 09-07-2021 02:28 PM
throttle valve cable/transmission kickdown cable stuck roll4life 3rd gen T4Rs 4 08-16-2016 02:03 PM
New ignition lock cylinder - won't engage ignition - 1996 base CanadaEh 3rd gen T4Rs 2 07-26-2016 03:18 PM
Spare tire cable bad, replace cable or carier? iBison 4th Gen T4Rs 10 06-16-2014 11:10 AM
