12-09-2022, 03:14 PM
Real Name: Bob
Real Name: Bob
99 3rd gen limited v6 running rich?
OK, I’ve searched the forum and I have found this topic leads me to discussions regarding coolant issues rather than rich air/fuel issues.
So after driving over 200 miles I noticed that while idling, the exhaust from my truck was smelling very gasoline Rich. I am asking if this is an issue that my truck might be running with a rich fuel mixture that is causing it to get worse gas mileage. And I was hoping to find out if there is a way to check the fuel mixture in the computer so that the fuel mixture will be more optimized rather than running rich.
I did notice that on this trip I was getting approximately 4 miles per gallon less than I would have expected.
Any suggestions would be appreciated!
12-09-2022, 03:40 PM
Real Name: Patrick
Real Name: Patrick
How many miles do you have? Has the air/fuel sensor ever been changed? IF the air/fuel sensor has never been changed then I would start there.
12-09-2022, 04:41 PM
Real Name: Bob
Real Name: Bob
265k miles. Was replaced a loooong time ago. I’ll give that a go as a start.
12-09-2022, 06:05 PM
What did you get and what did you expect for mileage? Modifications (lift, tires, racks, etc)? How fast were you going?
The ECU keeps what it *thinks* is stoichiometric A/F ratios for almost all running conditions. If the O2 or A/F sensor is bad, the fuel can be off somewhat.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
12-09-2022, 06:42 PM
Real Name: Patrick
Real Name: Patrick
I'd highly recommend a Denso one and to avoid ebay/amazon. I've tried aftermarket and got worse fuel economy so I ordered a Denso from eBay and it was a counterfeit.
12-09-2022, 08:24 PM
Vacuum leak could be causing it as well, and something you can check without throwing too much money at the truck. My truck is also running rich
12-10-2022, 12:35 PM
Probably best to watch the fuel trims and see what the ECU is reading first, then use the service manual to test MAF, TPS and upstream O2, either of which can cause a rich condition.
12-12-2022, 03:55 PM
Real Name: Patrick
Real Name: Patrick
Vacuum leaks cause the engine to run lean not rich.
03-30-2023, 03:31 PM
Real Name: Bob
Real Name: Bob
Been away for a while...
So I have NOT been able to change the O2 sensors but, I did change out my MAP sensor and cleaned the throttle housing.
My hwy mileage is still reasonable (17-21 conditions depending) but, after it's been running, the exhaust still smells "rich" to me. A gasoline heavy exhaust smell.
I'll try to update sooner and thanks for the suggestions.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
