Old 12-09-2022, 03:14 PM #1
Baughb's Avatar
Baughb Baughb is offline
Real Name: Bob
Baughb is on a distinguished road
Baughb's Avatar
Real Name: Bob
99 3rd gen limited v6 running rich?
OK, I’ve searched the forum and I have found this topic leads me to discussions regarding coolant issues rather than rich air/fuel issues.
So after driving over 200 miles I noticed that while idling, the exhaust from my truck was smelling very gasoline Rich. I am asking if this is an issue that my truck might be running with a rich fuel mixture that is causing it to get worse gas mileage. And I was hoping to find out if there is a way to check the fuel mixture in the computer so that the fuel mixture will be more optimized rather than running rich.
I did notice that on this trip I was getting approximately 4 miles per gallon less than I would have expected.
Any suggestions would be appreciated!
Baughb is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 03:40 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
How many miles do you have? Has the air/fuel sensor ever been changed? IF the air/fuel sensor has never been changed then I would start there.
Old 12-09-2022, 03:57 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+1 on the first oxygen sensor as that's always the air fuel ratio sensor. Could be something else but I definitely check that first. They do fail from time to time.
Old 12-09-2022, 04:41 PM #4
Baughb's Avatar
Real Name: Bob
Baughb's Avatar
Real Name: Bob
265k miles. Was replaced a loooong time ago. I’ll give that a go as a start.
Old 12-09-2022, 06:05 PM #5
What did you get and what did you expect for mileage? Modifications (lift, tires, racks, etc)? How fast were you going?
The ECU keeps what it *thinks* is stoichiometric A/F ratios for almost all running conditions. If the O2 or A/F sensor is bad, the fuel can be off somewhat.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-09-2022, 06:42 PM #6
Real Name: Patrick
Real Name: Patrick
I'd highly recommend a Denso one and to avoid ebay/amazon. I've tried aftermarket and got worse fuel economy so I ordered a Denso from eBay and it was a counterfeit.
Old 12-09-2022, 08:24 PM #7
CoCoCo4Runner CoCoCo4Runner is offline
CoCoCo4Runner is on a distinguished road
Vacuum leak could be causing it as well, and something you can check without throwing too much money at the truck. My truck is also running rich
CoCoCo4Runner is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 08:34 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Vacuum leak is mostly easy to find. Fire it up and use brake clean, wd 40 etc and mist all the areas of possible vacuum leaks if it speeds up you found your area that's leaking..
Old 12-10-2022, 12:35 PM #9
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Probably best to watch the fuel trims and see what the ECU is reading first, then use the service manual to test MAF, TPS and upstream O2, either of which can cause a rich condition.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 12-12-2022, 03:55 PM #10
Real Name: Patrick
Real Name: Patrick
Vacuum leaks cause the engine to run lean not rich.
Old 03-30-2023, 03:31 PM #11
Baughb's Avatar
Real Name: Bob
Baughb's Avatar
Real Name: Bob
Been away for a while...
So I have NOT been able to change the O2 sensors but, I did change out my MAP sensor and cleaned the throttle housing.
My hwy mileage is still reasonable (17-21 conditions depending) but, after it's been running, the exhaust still smells "rich" to me. A gasoline heavy exhaust smell.
I'll try to update sooner and thanks for the suggestions.
fuel , issues , mixture , rich , running
3rz running rich cantaloop 3rd gen T4Rs 2 07-02-2017 05:51 PM
Running rich at WOT? BoatRacer Classic T4Rs 0 03-02-2015 11:21 PM
Running Rich ? Dannoo93 Classic T4Rs 10 03-02-2012 10:55 AM
99 limited running rich Klamath4R 3rd gen T4Rs 3 11-27-2011 01:17 PM
running rich imboredeveryday 3rd gen T4Rs 5 08-17-2006 11:32 PM
