Old 12-14-2022, 04:31 PM #16
Originally Posted by the_welfare_wagon View Post
Yes exactly, I once heard the saying “I’m too poor to buy cheap shit”
I recently replaced the bushings so I had the rack all but removed so it should be an easy enough job to do again. Though with this cold I’ll probably wait till the leak gets worse and I’ll have the other OEM rack on standby. I’m sure someday soon I’ll come out of work and find a puddle underneath.
If you are going to wait for spring, put in some AT-205 in the system and it should reduce the leak until you can get to it...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-14-2022, 06:33 PM #17
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Yeah I’m gonna see if my local autozone has it on the way home. Then if not I’ll try Amazon. Hopefully I have good luck with it. If I can prevent the leak from growing till spring then I’ll be pretty happy
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 12-14-2022, 06:51 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It really should. Just slightly thicker fluid should slow the leak down... I don't blame you waiting to spring as it's kinda brutal outside here..
Old 12-14-2022, 06:58 PM #19
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
I drove mine with a pretty major rack leak/boot for a year, (I know, I know)
Just keep it topped off so you're not replacing a pump too...
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 12:21 PM #20
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Just bought new ITRs before I noticed my rack had a super small leak on it. The inside of the boot had a drip or two in it when I went to clean them up to reinstall them. That being said since I just dropped $ on the ITRs I think once the rack starts leaking a little more I’m going to attempt rebuilding the rack with an oem rebuild kit (roughly 90$ from partsouq). Definitely not for the faint of heart though. Here is the walkthrough I’ll be using when/if I do it. Part# for rebuild kit: 0444535160
Rack & Pinion Service Tools & tips | Tacoma World
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 12:41 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yep. Several videos out there on how its done and the pricing of the parts. It's really a no brainer as it's about 1/5 the cost of a remfg toyota one.
I honestly don't expect those toyota remfg ones will be around much longer.
Old 12-16-2022, 12:56 PM #22
T4topher's Avatar
T4topher's Avatar
I couldn’t find any videos of our specific rack being fully rebuilt. I did find one that had the top hat thing but wasn’t super detailed. All the other videos were for newer tacomas/T4r’s which are quite a bit different I think. Have a link for any of the videos your talking about?
Old 12-16-2022, 02:26 PM #23
GhostRing's Avatar
GhostRing's Avatar
It was enough of a yes brainer for me to keep the downtime to a minimum.
I figure the other 4/5 is chalked up to time, tools, and talent to get a rebuild under control...Would be fun to tackle, but it's my only vehicle for now.
That said, I have a '98 OEM rack up for grabs if someone wants to try their
hand at a refresh!
Build Etc...
Old 12-16-2022, 03:30 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
To each one's own.
Tim shared a link to a video of a guy resealing a steering rack. This video is close to an hour long.
I know that's what I will do if I need one. I will reseal a steering rack and have it ready to go for a swap. This elimates the down time as it's ready to go.
Old 12-16-2022, 03:32 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is in this thread above that Tim shared.
https://www.youtube.com/watch?v=NRdLsdymNP0&feature=youtu.be
Old 12-16-2022, 03:53 PM #26
T4topher's Avatar
T4topher's Avatar
Yea but that’s for a lexus rx300. The video might give a decent idea of what you’re getting into but ours are a bit different and have some special procedures.
Old 12-16-2022, 06:04 PM #27
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I look in my fsm and see. The Lexus rx300 has to be close. To me a rebuild is just a reseal. If your Tie rod ends are toast from washing the grease out. I would look into decent aftermarket ones as Like other posts say the cost of the tie rod ends are like the toyota CV axles way too expensive.
(The only exception would be heavy off roading then probably best to use OEM ones)
Once rack starts leaking, that's what washes the grease out. So you have to get it quick or keep is greased to save those inner tie rods.
There really should be some half decent inner tie rod 3rd party tie rods isn't there?
dollar , leak , oem , rack , steering
Steering Rack Leak blaze17 3rd gen T4Rs 2 05-19-2017 08:02 AM
Power steering leak/steering rack SRQ-Runner 3rd gen T4Rs 1 10-25-2014 02:13 PM
Steering Rack Leak Aelfwine 3rd gen T4Rs 4 07-12-2014 09:39 PM
Possible Steering Rack Leak???? ryankmasuda 3rd gen T4Rs 5 01-30-2012 01:48 AM
Leak on the Steering Rack CT4R 3rd gen T4Rs 3 11-08-2011 06:04 PM
