Old 12-19-2022, 09:47 AM #1
OpenYota's Avatar
OpenYota OpenYota is offline
OpenYota is on a distinguished road
OpenYota's Avatar
Battery almost died while at stop light, now I'm hearing a dull buzzing sound
My battery has been dying for a little while but when I was at the stop light the other day my battery light came on and the radio turned off but the 4runner didn't shut down.
I turned off the lights, radio, and AC and went straight to the store and bought a new battery.
Only now I have a dull humming/buzzing sound coming from the engine bay.
I can hear it when it's in park and it slightly gets louder when I accelerate/reverse and can hear it adjust in volume when the AC compressor kicks on.
Is it the alternator that needs replacing now?
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old 12-19-2022, 10:13 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Who knows - why not have it tested?
Any autozone or like place will test the battery and charging system for FREE.
Old 12-19-2022, 11:20 AM #3
I had a diode block go bad and the more of a load the Alt had the higher and louder the whine got.
What’s your voltage running at.
My scangauge shows system voltage but you can buy a volt meter that plugs into the cig lighter. I have two types. One is just a voltmeter and the other is a usb charger that shows voltage when not in use or charging current.
Old 12-28-2022, 01:09 PM #4
OpenYota's Avatar
OpenYota's Avatar
Update: The alternator tested good and is running around 14.2 volts.
Still am unable to identify what the whine could be
2001 SR5 4WD
Old 12-28-2022, 01:16 PM #5
Remove a belt and start the engine and see if removing anyone makes the noise go away.
Old 12-28-2022, 06:49 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Start removing belts and starting the engine to see if the noise goes away. Or get a mechanic’s stethoscope to use.
battery , hear , light , stop , turned
Battery Light started blinking then the car died and now car won't start! robaroni 4th Gen T4Rs 7 04-05-2017 10:25 PM
Droning sound...hearing impaired 4Runner owner Anonymous4Runner 4th Gen T4Rs 2 03-04-2017 12:35 AM
Battery died...now TPMS light is on Flyer Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-14-2016 11:42 PM
Before I take it in. light buzzing sound when braking jtex 5th gen T4Rs 4 08-18-2015 04:27 PM
Sound I'm Hearing at Low Speeds adoihcj 5th gen T4Rs 22 01-17-2011 09:03 PM
