Old 12-24-2022, 12:16 AM #1
aa010175's Avatar
aa010175 aa010175 is offline
Real Name: Dave
aa010175 is on a distinguished road
aa010175's Avatar
Real Name: Dave
PO172 code after Cylinder Head replacement
I had a cracked cylinder head fixed and replaced the water pump, timing belt, fuel injectors (rebuilt). Also a few months ago I replaced the spark plugs and wires. I now have a PO172 code with System too rich bank 1. I cleaned the MAF and no help on the code. I understand one of the rebuilt injectors could be leaking fuel. How do you test for the bad one? Thanks Dave
aa010175 is offline   Reply With QuoteReply With Quote
Old 12-24-2022, 01:05 AM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The best way to test is using a multimeter to measure resistance at each injector. We have high impedance injectors so if one is significantly lower than the rest that's your leaky injector.
326WHP 347TQ
Old 12-24-2022, 07:51 PM #3
19963.4lsr5 19963.4lsr5 is online now
Drive it a while and look at each spark plug. The one with the darkest signature is the cylinder running rich.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 12-25-2022, 01:46 AM #4
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
Is bank 1 on the driver’s side? Thanks Dave
Old 12-25-2022, 10:31 AM #5
All 6 cylinders are Bank 1
Old 12-25-2022, 09:07 PM #6
Texmax's Avatar
Texmax Texmax is offline
Texmax is on a distinguished road
Texmax's Avatar
Had a po 171, I found the throttle body gasket in upside down, did you pull that off?
Why did you replace the Injectors?
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 12-25-2022, 10:16 PM #7
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
OMG you have to be kidding with me…. 😡
Old 12-25-2022, 10:22 PM #8
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
I did not remove the throttle body. I replaced the injectors because the had 250,000 miles on them and I had the engine stripped down. Dave
Old 12-26-2022, 12:29 AM #9
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
The Bank 1 refers to the O2 Sensor. That's what's reporting the too lean problem. Single side exhaust system, so only 1 "Bank". Hope this helps clear up the confusion.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 12-26-2022, 07:31 AM #10
OMG you have to be kidding with me…. PO172 code after Cylinder Head replacement
It would be nice if Toyota had split the fuel management into two banks. But they did not.
Old 12-28-2022, 06:19 PM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Where did you get the injectors from? If you still have your old injectors I would put those back in and see what your fuel trims are.
code , fuel , injectors , po172 , replaced
Cylinder head replacement - questions LS-4Runner 3rd gen T4Rs 6 01-15-2022 09:11 PM
CEL Code - P0302 - Cylinder #2 Misfire Agriess 4th Gen T4Rs 2 07-18-2018 09:30 PM
97 3rd gen 3.4 P0302 cylinder 2 misfire code sea_stork 3rd gen T4Rs 21 06-28-2018 05:27 PM
Misfire Code P0308 cylinder 8 question PSUPOWER 4th Gen T4Rs 0 01-17-2013 07:19 PM
Cylinder Head Replacement.. NEED HELP 95_Dusty Classic T4Rs 2 11-13-2011 10:58 PM
