Old 12-28-2022, 11:30 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by aa010175 View Post
I put the car all back together after finding nothing wrong that I can see. The car started up and ran normally. But before I started the engine I looked at the codes again that was tripped. It had a PO300 random multiple cylinder misfire detected and a P0303 cylinder 3 misfire detected and a PO304 cylinder 4 misfired detected. After driving it 2 miles PO172 system to Rich bank one showed up again but nothing else. What would make cylinders 3 and 4 misfire and could a misfire trip a P0172 code? Thanks Dave
Unburnt fuel from misfire(s) will cause a rich code. Fix your misfire problem and the P0172 will likely go away. If your spark plugs for cylinders 3&4 are wet with fuel then you have a spark problem or too much fuel for the mixture to spark and ignite. A bad injector seal will not show up in resistance testing. Do you still have your old injectors?
belt , engine , missing , rebuilt , timing
Techstream Real time Engine Data Woes Tj900 5th gen T4Rs 6 01-31-2021 12:44 PM
Engine missing razerface 3rd gen T4Rs 24 01-05-2017 05:52 PM
Autozone proformance engine real? johnathandm 3rd gen T4Rs 5 04-09-2011 05:33 AM
Need help with missing engine iwilli1169 3rd gen T4Rs 1 01-22-2008 10:03 PM
Engine a real slouch 91runner Maintenance/Detailing 4 03-27-2004 03:05 PM
