Originally Posted by Buckaroo
Is the P0172 the only code you have? Would think maybe you should be seeing a P0304? Wet plug could be too much fuel or no spark. Check your spark plug routing per attached. Look for evidence of arcing on cylinder 4 spark plug boot. You could try disconnecting the wire to the cylinder 4 injector and see if it changes anything. You could swap that cylinder 4 spark plug to a different cylinder and see if the "wet" observation follows it. Make sure the plug to the MAF is secure and do a visual check on the wiring to it. You likely know this but driving with that miss will kill your CAT.
I had to have the car towed to my house it was running so bad. I have been driving it for 100 miles with no problem. Down the freeway 70 mph, short trip to the store etc. the only code was the P0172 with rich note. It was running good then all of the sudden it went to very ruff like 3 cylinders and it was back firing every few minutes. I just pulled all injectors and blew gas out of them well hot wiring the ejectors. Plug wires are correct. Thanks for the diagram. The plugs and wire are new 4 months ago.
