Old 12-28-2022, 09:34 AM #1
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Checklist for 35s? Or am I just dreaming.
Hey y’all. I’m about to pull the trigger for the jump to 35s.
Right now I have 285/75/16, no issues with rubbing except reversing at full lock.
• I’m going to be getting 35x10.5r17s. Going to be tubbing the wheel wells and fenders.
• Not sure what wheels yet. Some TRD Pro ones would be cool. Or just some steelies. Suggestions?
• I have 1.25” spidertrax, depending on wheel offset, I can keep or remove those.
• I have a 1” BL not installed, should I throw that on, too? Also a front spacer, less than 1”.
• JBA UCAs?
• Will get 4.88 gears most likely.
What else?
edit: this is how she sits now Imgur: The magic of the Internet. OME 891 and 890 with billy 5100s.
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 12-28-2022, 11:30 AM #2
RomanSchnobrich's Avatar
RomanSchnobrich RomanSchnobrich is offline
Real Name: Roman Schnobrich
RomanSchnobrich will become famous soon enough
Are you planning to tub your firewall yourself? Here's an awesome and detailed writeup on it either way. You'll definitely want some aftermarket UCAs, most folks will point you towards SPCs so you can adjust your tires as far forward away from the firewall as possible. Aftermarket bumpstops (Durobumps or Timbrens) will be your friend as well.
DIY: Tubbing the firewall to clear 35" tires (3G4R)
2000 SR5 Midtravel Cookie Cutter Build
https://www.instagram.com/roamin.creative/
RomanSchnobrich is offline   Reply With QuoteReply With Quote
Old 12-28-2022, 11:32 AM #3
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
I’d probably get 5.29 gears with 35s, if it’s a manual then 4.88 might be ok
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 12-28-2022, 01:58 PM #4
blairracd's Avatar
blairracd's Avatar
Thank you! No, not myself, I’m going to have someone do it. Definitely new UCAs; I’ve been meaning to do that ever since I got the 285s on.
Oh, SPCs? I thought most folk said JBAs — I remember doing a lot of research between the two and I still have a bookmark for the JBAs only.
I will add bump stops to the list as well!
RIP my ‘96.
Old 12-28-2022, 02:00 PM #5
blairracd's Avatar
blairracd's Avatar
I’m still debating between the two. It is an automatic. The reason I am leaning towards 4.88 rather than 5.29 is just for the “just in case” I ever move back down; though I don’t plan to. I’m going to be getting a Tacoma soon, so the 4R will be moving over to my weekender.
RIP my ‘96.
Old 12-28-2022, 02:05 PM #6
blairracd's Avatar
blairracd's Avatar
Should I have the 1” body lift installed, too? Ditch or keep the spacers?
RIP my ‘96.
Old 12-28-2022, 04:07 PM #7
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
I don't think those JBA's have a caster adjustment like the SPC's, which you will certainly want.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 12-28-2022, 10:17 PM #8
blairracd's Avatar
blairracd's Avatar
Gotcha! I will be looking for those then, thank you!
RIP my ‘96.
Old 12-28-2022, 10:21 PM #9
blairracd's Avatar
blairracd's Avatar
What size/length bumpstops?
RIP my ‘96.
Old 12-29-2022, 01:25 PM #10
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I highly recommend the 1” body lift. It might even get rid of the rubbing you’re getting now.
I can’t answer your spacers question. You’ll know if you need them. I have the 1.25” Spidertrax on my 4th gen. I don’t know if I need them, but I like the look with them.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 12-29-2022, 02:05 PM #11
blairracd's Avatar
blairracd's Avatar
It certainly would help for now. I did a lot of cutting and hammering before and I only rub a little bit in reverse at full lock or when my suspension fully cycles. I am going to be going with 35x10.5r17s, though, so I’m thinking that I might not need it, and want to keep the COG as low as possible.
RIP my ‘96.
Old 12-29-2022, 02:15 PM #12
That'll depend on how much lift you want to achieve. I have the extended versions as my 4Runner has a decent lift, maybe 4" higher in the back and 2.5" higher in the front. Interestingly enough, Durobumps used to offer an extended version for the front but it doesn't seem like that's the case anymore.
You also have to consider if you'd rather be hitting your bumps too early or late-- would you rather lose some of your shock travel or risk damaging/blowing your shocks?
3rd Gen Archives - DuroBumps - Toyota Bump Stops for 4Runner, Tacoma, Tundra, FJ Cruiser
Old 12-30-2022, 01:29 PM #13
blairracd's Avatar
blairracd's Avatar
I’m around the same lift as you. And definitely earlier.
RIP my ‘96.
35s , depending , i’m , offset , wheel
More fun dreaming or doing? WakeTime New Members 0 12-04-2020 12:29 AM
Motor dreaming Myrunr2010 3rd gen T4Rs 25 02-26-2016 04:31 PM
Dreaming Big !!! ICON Stage 7 TheWraith 5th gen T4Rs 9 11-02-2014 11:13 PM
the perfect 4th gen, dreaming of badfeather 4th Gen T4Rs 3 06-03-2013 08:53 AM
sort of day dreaming lmoody003 5th gen T4Rs 1 05-03-2011 12:29 AM
