Old 09-18-2015, 10:01 AM #1
RC57 RC57 is offline
RC57 is on a distinguished road
Rear Hatch Strut Options
I have a 99 4Runner LTD, 200k miles, with worn out bushings on the rear hatch struts. Toyota doesn't sell the bushings alone, only struts with bushings for $200+ each.
Does anyone know a source for bushings, or alternatively aftermarket struts that include bushings? All the aftermarket I've seen are sold without bushings.
The struts themselves are doing ok, however it wouldn't hurt to freshen them up too. They allow the door to sag a few inches. The biggest problem for now is disintegrated bushings.
-RC
1999 Ltd 4x4
RC57 is offline   Reply With QuoteReply With Quote
Old 09-18-2015, 11:40 AM #2
Range Range is offline
Range is on a distinguished road
High Quality Automotive | Marine | Industrial Lift Supports
Forget the bushings. Just replace everything with a set of these. Toyota can suck a fat baby's di*k with their $200 lift supports. I have a set of these along with many other guys on this site and they're better than OEM. They're also just as good as the ones Gobi sells yet a hell of a lot cheaper and they're not sold by a bunch of gimps. I have a set and even with a ladder my lift gate springs upward fast enough to knock your ass out if you're standing too close.
2004 Limited V8 w/ Factory Nav- OME Front Heavy Coils, OME Rear Medium Coils [] ProComp ES9000 shocks all around [] Shrockworks Single Hoop Bumper w/ PIAA Super White Driving Fog Lights [] Shrockworks Sliders [] KC 4" x 6" Gravity LED Driving Light [] Clazzio Black Seat Covers - Front and Rear [] Spidertrax 1.25" spacers [] Pro Comp MT2 285x70x17 [] 2006 Headlight Mod [] Satoshi Grille [] Black Canvas Back Canvas Jackets [] Black Husky Liners Front and Back [] Gobi Stealth Rack & Ladder
Range is offline   Reply With QuoteReply With Quote
Old 09-18-2015, 11:52 AM #3
Nice looking supports, great price. Do they come with bushings?
1999 Ltd 4x4
Old 09-18-2015, 11:56 AM #4
I_bRAD I_bRAD is offline
I_bRAD is on a distinguished road
If you pull the old ones and measure them you can likely get them for a few bucks at mcmaster carr
I_bRAD is offline   Reply With QuoteReply With Quote
Old 09-18-2015, 12:01 PM #5
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
I also used these supports and they are great, none of the supports come with bushings, but you can make your own as someone on this site has pics. I can not find the post right now, but if you do a search you may come up with the info.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 09-18-2015, 12:23 PM #6
are you guys going for the standard or increased force versions?
Old 09-18-2015, 01:02 PM #7
Back when I had access to a lathe I would have spun something up in a few minutes. No longer.
1999 Ltd 4x4
Old 09-18-2015, 01:16 PM #8
I have a 4th Gen so there's only one type available and they are the "Strong Arm Supports". I'm guessing they are the standard which are ridiculously strong to begin with. I may be wrong though. Either way, they are very robust and the spring rate didn't change with the weather.
Old 09-18-2015, 02:17 PM #9
MONTYMTB's Avatar
MONTYMTB MONTYMTB is offline
Real Name: Monty
MONTYMTB is on a distinguished road
MONTYMTB's Avatar
Real Name: Monty
FYI - If you get them from their ebay store, they offer free shipping:
Qty 2 Strongarm 4286 Rear Liftgate Hatch Tailgate Lift Supports Struts Shocks | eBay
'99 Limited 4WD, V6, Auto
MONTYMTB is offline   Reply With QuoteReply With Quote
Old 09-18-2015, 03:33 PM #10
bugman-74's Avatar
bugman-74 bugman-74 is offline
bugman-74 is on a distinguished road
bugman-74's Avatar
I have the strongarm's on mine, and they are great. Pick up some nylon spacers and washers from Ace to make your own bushing. I had a buddy cut down the spacers on his lathe (1/2" long I believe), but it can be done by hand. There is a thread or two around here that talks about this.
Rear Hatch Strut Options-img_6663_587x480-jpg
bugman-74 is offline   Reply With QuoteReply With Quote
Old 09-19-2015, 12:31 PM #11
Pic is quite helpful. Got an Ace around the corner.
1999 Ltd 4x4
Old 09-25-2015, 07:02 PM #12
Ace hardware didn't have the bushings I needed. Their selection had been hopelessly mixed and pilfered. I went to Lowe's and found what I needed. I cut the 1" length inner bushing down to ~11.5mm length with a hacksaw. It's a decent fit. The side washers I left as is, using one on each side. Here's some pics showing the parts bags, inner bushing before and after cutting, then installed.
Thanks for the suggestions!
Rear Hatch Strut Options-fullsizerender2-jpg  Rear Hatch Strut Options-fullsizerender-jpg  Rear Hatch Strut Options-fullsizerender3-jpg
1999 Ltd 4x4
Old 12-30-2017, 06:38 PM #13
5vzfe817 5vzfe817 is offline
Real Name: JD
5vzfe817 is on a distinguished road
Real Name: JD
Winner winner!
...Ace hardware didn't have the bushings I needed. Their selection had been hopelessly mixed and pilfered. I went to Lowe's and found what I needed. I cut the 1" length inner bushing down to ~11.5mm length with a hacksaw. It's a decent fit. The side washers I left as is, using one on each side. Here's some pics showing the parts bags, inner bushing before and after cutting, then installed.
This was EXACTLY the thread I needed at the right time! The top openings mic'd out to 0.470 and I used a tiny pipe cutter to score the bushing to ~0.472 straight. I then used a sanding block to trim it down. Looks way better than this pic shows (after all, it is zoomed in). Definitely would have preferred black nylon, but didn't realize there were even any bushings/problems (mine were beyond destroyed) until we (wifey joined me) were committed! Got the struts from RockAuto:
MONROE 901446 Lift Support $ 13.33ea *2 + shipping $33.55...ain't no way I am paying OEM prices for this and ~$2.50 for washers/bushings.
5vzfe817 is offline   Reply With QuoteReply With Quote
Old 02-21-2019, 07:09 PM #14
00CaliRunner 00CaliRunner is offline
00CaliRunner is on a distinguished road
Monroe vs Strongman struts
Anyone have experience with either of the strongman struts, or monroe? Shaun & timmythetoolman just released a video on this repair, it looks like the stronger strongman struts are still $$$. I am wondering how the monroe hold up, as it seems the lower level strongman struggle in the cold weather. I have been needing this repair for sometime, however was able to revitalize my stock struts using a little white lithium grease, must have just improved the seal, and it will remain up unassisted in warm weather now, as long as the window is up.. Either way interested in the better strongman struts, or an equivalent.
Yet another helpful video from the TimmyTheToolman Team!
00CaliRunner is offline   Reply With QuoteReply With Quote
Old 02-21-2019, 07:53 PM #15
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
I must have missed it but the last video I saw him do was on the hood strut install not the rear hatch struts or bushings?? I got the basic ones off ebay that work fine, they were 40$ or so...nothing fancy and work better since I replaced the bushings, didn't know they were binding.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Hatch strut question Bigmd 3rd gen T4Rs 3 02-13-2015 04:39 AM
having trouble getting rear strut out tacozappy 4th Gen T4Rs 10 06-10-2013 09:06 PM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
WTB: 3rd Gen. Rear Hatch strut/support brackets blarchitect For Sale: T4R Items 0 02-21-2012 10:16 AM
Disassembling Rear Hatch -> Stuck Rear Window MunkeyTX 3rd gen T4Rs 1 09-02-2008 10:48 PM
