Old 01-01-2023, 12:38 AM #1
aa010175's Avatar
aa010175 aa010175 is offline
Real Name: Dave
aa010175 is on a distinguished road
aa010175's Avatar
Real Name: Dave
Hot Wire/Jump a fuel pump?
I have fuel leakage from the injectors to the fuel railings. 4 or 5 of them are leaking. I would like to replace the bad O-rings and then test out the fuel railings and pressure prior to putting the whole upper engine back together and again finding out it’s still leaking. Is there anyway to activate the fuel pump without the engine running? Thanks Dave
aa010175 is offline   Reply With QuoteReply With Quote
Old 01-01-2023, 02:44 AM #2
rcvxl24's Avatar
rcvxl24 rcvxl24 is offline
rcvxl24 is on a distinguished road
rcvxl24's Avatar
Yes, if you have an extra battery laying around (car, lawnmower, etc) you can hook the leads up to the fuel pump and jump it.
rcvxl24 is offline   Reply With QuoteReply With Quote
Old 01-01-2023, 08:28 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
There is a way from the diagnostic port but it has been a very long time since I have done it on a Toyota. +B is the fuel pump power wire you just have to ground it and I don't know which is the diagnostic port ground. Be sure to have some spare fuses on hand as if you get it wrong the fuse will blow.
326WHP 347TQ
Old 01-01-2023, 08:57 PM #4
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
Do you mean the test port that it’s under the hood? I found B+. Are saying to just ground it out and the fuel pump will run? Thanks Dave
Old 01-01-2023, 09:34 PM #5
Real Name: Jerod
Real Name: Jerod
Yes the Test/Diagnostic port under the hood. I just don't remember which is ground. You'll hear it run if it works. Like I said though, don't strand yourself and make sure you have replacement fuses. E2 used to be the ground on old Toyotas but I didn't see one labelled as such last I checked. You'll ground it by running a paper clip or small section of wire from +B to the ground wire on the diagnostic port. I suppose you could try just connecting it to the ground right there on the side of the intake and see if that does it.
Once you have the correct ground turn the key to "On" but don't start the engine. You should hear the pump run if it works.
326WHP 347TQ
Old 01-01-2023, 09:47 PM #6
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
Thanks so much for the information. I will give it a try and report back. Dave
Old 01-01-2023, 11:24 PM #7
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
Here’s the photo I found to use’s.
Hot Wire/Jump a fuel pump?-830d0efc-5dba-4669-872b-caf384949740-jpg
Old 01-03-2023, 03:20 PM #8
Real Name: Jerod
Real Name: Jerod
Did jumping those terminals work? Toyota must have changed their diagnostic procedures at some point.
326WHP 347TQ
Old 01-03-2023, 05:53 PM #9
On OBD-I Toyotas, jumpering Fp and B+ in the diagnostic port (same connector still used on the gen3 4Runner on the intake manifold) would power the fuel pump with the key ON. I'm not sure if the connections are still there in the connector on the 4Runner. Otherwise the fuel pump will only be powered with the key in START or the engine is actually running.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-16-2023, 07:01 PM #10
loneshepherd loneshepherd is offline
loneshepherd is on a distinguished road
Did that work? my 97 5VZ 4R doesn't have a pin to use in the Fp slot.
Hot Wire/Jump a fuel pump?-diagport-jpg
loneshepherd is offline   Reply With QuoteReply With Quote
engine , fuel , leaking , pump , railings
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
Fuel Pump Relocation? or Fuel Pump Hatch? Cygnus 3rd gen T4Rs 3 01-24-2022 03:06 PM
No Fuel? Bad Fuel Pump? Bad Fuel? Aliens? Gremlins? 007Tacoma 5th gen T4Rs 12 05-04-2018 09:08 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
