Old 01-03-2023, 08:52 PM #16
Originally Posted by gamefreakgc View Post
Are you 100% sure the heater valve is working? I don't mean the cable is moving, can you confirm that your heater valve is not just sealed shut and broken? They break pretty easy - every time I've taken off a heater line off the valve it has broken on me. That would be the only thing making sense that would stop coolant flow in its tracks but not block flow in the engine. By the way, I can also take my radiator cap off when it's 'warmed up' after 5-10 minutes. I CANNOT take it off when it's actually hot after driving for say, 20 minutes or more as it sprays out like a fountain. Yes I've done it by accident.
I’m pretty sure he mentioned bypassing the heater valve. That’s why I suggested the pipe under the intake is blocked
I know his problem is legit, but it makes no sense.
Old 01-03-2023, 09:13 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Even if the IAC valve hose clogged, if I am looking at the flow diagram properly, it looks like that port and the heater port are shared on the casting. Maybe I am wrong.
I just wouldn't think they have anything restricting that heater core feed except the heater core control valve. As folks would want heat as soon as possible, this is probably why the port is where it is.
Old 01-04-2023, 01:44 AM #18
rcvxl24's Avatar
rcvxl24 rcvxl24 is offline
rcvxl24 is on a distinguished road
rcvxl24's Avatar
Quick update: like gamefreak mentioned, I was able to get the system up to pressure after driving around a little bit (still cleaning coolant out of all the crevices No coolant flow to brand new heater core).
And as I mentioned in the original post, the heater valve has been bypassed.
I studied that cooling system diagram before starting this thread and while it is good enough to give me a general idea of the circuit, the arrows are so poorly drawn that it leaves me scratching my head when I try to put together exactly whats going on.
I plan on putting some work into it this weekend.
rcvxl24 is offline   Reply With QuoteReply With Quote
Old 01-04-2023, 10:47 AM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree it's definitely a head scratcher for sure.
Old 01-07-2023, 04:10 PM #20
spartacus's Avatar
spartacus's Avatar
Originally Posted by rcvxl24 View Post
Hello everyone, long time first time. Starting a thread is usually my last resort, and well here I am.
Battling a no heat issue on my 1998 Limited V6 2WD. More specifically, I'll occasionally get some lukewarm heat, but after running the fan for half a minute or so it'll go cold.
Background:
  • Coolant gage always sits barely below the middle
  • Scanner says coolant is reaching ~188F
  • The heat has never worked since I've owned it
  • The tees that go to/from the rear heater have been plugged
Attempts to solve:
  • Brand new Spectra heater core
  • Verified blend doors are working correctly
  • Verified heater valve was working
  • Bypassed heater valve
  • New OEM thermostat
  • 5-10 system bleeds
  • New Radiator Cap
  • Back flushed new heater core
  • Back flushed engine/radiator
Here's the interesting thing. I replaced a section of hose before the heater valve with clear tubing and saw that with the truck running, the coolant is just sitting there; virtually no flow into the heater core.
Also, the system is not building pressure. After running and getting up to operating temp, you can pull the radiator cap off (even the new one) with no problem.
Am I missing anything? I'm pulling my hair out.
I am not sure if this would help but the part# for 96-98 is 87240-35050 and the part number for 99+ is 872403-5070.
Old 01-10-2023, 12:57 AM #21
rcvxl24's Avatar
rcvxl24's Avatar
So I think I’m one step closer to solving. I got the vacuum coolant refill kit snd it works great, confirmed the system has no leaks and is bled well. But did not solve the issue.
An additional symptom that I’ve been able to consistently recreate is that the heater upon startup/idle will actually works pretty good, but as soon as I start driving and (presumably) the thermostat opens up, the heat goes away.
I also pulled all the coolant lines between the engine and heater core to check for any blockages. No smoking gun, but while all the hoses were off i did stick a 14gauge solid wire as far down into the coolant bypass (under the intake) as i could and when i pulled it out it was filthy with a bunch of crap on it. When i bought this truck a year and a half ago the coolant looked absolutely atrocious and had tons of gunk everywhere, so this is not surprising.
To me, this is seeming like a clogged coolant bypass. My valve cover gaskets are leaking oil, so I’m seeing this as a great opportunity to replace those and inspect the bypass while I’m in there. I will order parts for that job this week.
Old 01-10-2023, 09:29 AM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Is it possible that your thermostat is just bad? As a defective thermostat will do exactly what you are seeing. The works when first start up then after warm up no heat. Is sounding to me like the thermostat is sticking open. A stuck open one.
Do you know of the thermostat is oem or aftermarket?
Old 01-10-2023, 10:58 AM #23
rcvxl24's Avatar
rcvxl24's Avatar
I could be wrong, but I don’t think it’s the thermostat. A few reasons:
- brand new OEM thermostat as of fall 2021
- that wouldn’t explain the lack of flow to the heater core
- my coolant temp always stays at ~188F, if it was stuck open I’d imagine it would fluctuate based on demand and ambient temperature
Old 01-10-2023, 11:29 AM #24
Pull out the thermostat and force water through the coolant bypass and let it run until you see clean water and no chunks. It’s the only thing that made sense. Hopefully it’s the issue.
Potentially that crap will migrate into your new heater core so back flushing that is a good idea also.
Old 01-10-2023, 07:41 PM #25
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Sounds like somebody put a bottle of stop leak in there. That stuff ends up doing more damage than it helps.
326WHP 347TQ
Old 01-11-2023, 12:10 AM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+1 stop leak was used in the past. This would explain the clogging.
Agreed the thermostat would have the coolant temp fluctuate especially if sticking open. :-)
That stuff will plug all kinds of things up. It really should be completely pulled off the market. :/
Old 01-11-2023, 12:34 AM #27
rcvxl24's Avatar
rcvxl24's Avatar
Yes, I agree stop leak was likely used by a previous owner. Reason being, there is an external repair job on my radiator (that surprisingly doesn’t leak) that was probably done in tandem with the stop leak. Sometime in the future I’ll replace the radiator with a new Denso, but it’s not a priority for me right now.
coolant , core , heater , running , valve
Help finding coolant leak 94 runner 22re. Maybe heater core… Soulprogression108 Classic T4Rs 3 06-08-2021 10:35 PM
FS: OEM Brand new 3rd Gen Heater Core/HVAC Unit - $200, Regina,SK 97sr5 For Sale: T4R Items 3 08-28-2020 03:58 AM
Heater Core shawnstcyr 3rd gen T4Rs 12 08-19-2015 03:54 PM
how to drain coolant from engine/heater core 1995 3VZ-E odoyle81 Classic T4Rs 5 07-01-2015 05:11 PM
Coolant / heater core / rust problem pwalsh53 3rd gen T4Rs 1 10-02-2007 01:51 AM
