Old 01-01-2023, 01:41 PM #1
rcvxl24's Avatar
rcvxl24 rcvxl24 is offline
rcvxl24 is on a distinguished road
rcvxl24's Avatar
No coolant flow to brand new heater core
Hello everyone, long time first time. Starting a thread is usually my last resort, and well here I am.
Battling a no heat issue on my 1998 Limited V6 2WD. More specifically, I'll occasionally get some lukewarm heat, but after running the fan for half a minute or so it'll go cold.
Background:
  • Coolant gage always sits barely below the middle
  • Scanner says coolant is reaching ~188F
  • The heat has never worked since I've owned it
  • The tees that go to/from the rear heater have been plugged
Attempts to solve:
  • Brand new Spectra heater core
  • Verified blend doors are working correctly
  • Verified heater valve was working
  • Bypassed heater valve
  • New OEM thermostat
  • 5-10 system bleeds
  • New Radiator Cap
  • Back flushed new heater core
  • Back flushed engine/radiator
Here's the interesting thing. I replaced a section of hose before the heater valve with clear tubing and saw that with the truck running, the coolant is just sitting there; virtually no flow into the heater core.
Also, the system is not building pressure. After running and getting up to operating temp, you can pull the radiator cap off (even the new one) with no problem.
Am I missing anything? I'm pulling my hair out.
rcvxl24 is offline   Reply With QuoteReply With Quote
Old 01-01-2023, 02:20 PM #2
heat's Avatar
heat heat is online now
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
No mention of water pump.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is online now   Reply With QuoteReply With Quote
Old 01-01-2023, 03:16 PM #3
rcvxl24's Avatar
rcvxl24's Avatar
My logic is that if the water pump wasn’t working correctly, it would be overheating. This thing has never even thought about overheating as long as i’ve had it, even with AC on full bast in the summer.
Old 01-01-2023, 03:28 PM #4
Texmax's Avatar
Texmax Texmax is offline
Texmax is on a distinguished road
Texmax's Avatar
no flow, no pump. no pressure, no pump. pump time.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 01-01-2023, 05:09 PM #5
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
I agree it's not the pump if it's not overheating.
It's not the pump that builds the pressure it's the coolant temp.
It's a circulating pump, not a pressure pump.
Do you know anyone with a 4runner or Pickup with the same motor so you could compare hose routing?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 01-02-2023, 12:10 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I concur: Look at the hose routing.
pluton is offline   Reply With QuoteReply With Quote
Old 01-02-2023, 05:24 PM #7
The pipe under the intake may be clogged. You could remove the Rad cap and blow some compressed air through it.
Old 01-02-2023, 06:49 PM #8
rcvxl24's Avatar
rcvxl24's Avatar
Thanks everyone. I have a ‘98 FSM on the way that I will use to confirm hose routing. I believe the heater core outlet goes to the line underneath the intake - can someone confirm?
To rule out air in the heater core (and confirm no system leaks) I have a cooling system vacuum refill kit on the way too.
Old 01-02-2023, 06:52 PM #9
Here's a coolant flow diagram for the 5VZ-FE.
No coolant flow to brand new heater core-coolant-flow-2-jpg
Old 01-02-2023, 08:51 PM #10
pluton's Avatar
Real Name: Keith
pluton's Avatar
Real Name: Keith
Note: The above diagram shows an EGR valve, which does not exist on our 4Runners.
Old 01-02-2023, 09:21 PM #11
With nothing wrong and a good Rad Cap all you should need to do is fill the Rad to the top and ensure the expansion tank is filled to the top mark and heat cycling the engine around three times does the rest.
With a cold engine, if you remove your Rad cap is coolant touching the cap?
Old 01-03-2023, 04:31 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes with an * that's sure not a diagram of a 4 cylinder that's a v6 so in some parts of the world maybe the EGR is there just not in the us and canada market. :-)
Old 01-03-2023, 05:36 PM #13
I believe you're right.
Old 01-03-2023, 07:10 PM #14
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
Are you 100% sure the heater valve is working? I don't mean the cable is moving, can you confirm that your heater valve is not just sealed shut and broken? They break pretty easy - every time I've taken off a heater line off the valve it has broken on me. That would be the only thing making sense that would stop coolant flow in its tracks but not block flow in the engine. By the way, I can also take my radiator cap off when it's 'warmed up' after 5-10 minutes. I CANNOT take it off when it's actually hot after driving for say, 20 minutes or more as it sprays out like a fountain. Yes I've done it by accident.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 01-03-2023, 08:25 PM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sometimes I am... and when I am not, the other members correct me..
coolant , core , heater , running , valve
Help finding coolant leak 94 runner 22re. Maybe heater core… Soulprogression108 Classic T4Rs 3 06-08-2021 10:35 PM
FS: OEM Brand new 3rd Gen Heater Core/HVAC Unit - $200, Regina,SK 97sr5 For Sale: T4R Items 3 08-28-2020 03:58 AM
Heater Core shawnstcyr 3rd gen T4Rs 12 08-19-2015 03:54 PM
how to drain coolant from engine/heater core 1995 3VZ-E odoyle81 Classic T4Rs 5 07-01-2015 05:11 PM
Coolant / heater core / rust problem pwalsh53 3rd gen T4Rs 1 10-02-2007 01:51 AM
