01-03-2023, 11:08 PM
Real Name: Dave
Real Name: Dave
Fuel Injectors O-Ring grease help.
I purchased MotorWest rebuilt Fuel Injectors and need grease ideas for the O-Rings. The Toyota parts man told me to use white Lithium grease.
01-03-2023, 11:41 PM
If you ordered through motor west they should have included a small plastic sleeve of "superlube"
Look through the contents of the package thoroughly.
01-03-2023, 11:51 PM
Real Name: Dave
Real Name: Dave
Thanks. I have not received them yet. Nice to know there will be grease provided. Dave
01-04-2023, 01:29 AM
Superlube is good stuff but if none is provided, Vaseline or chapstick works good
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
01-04-2023, 08:37 AM
Real Name: Charlie
Real Name: Charlie
I just used motor oil on mine. No problems after ~30k miles
Originally Posted by STX4Runner
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
01-04-2023, 09:03 AM
I think motor oil is what the FSM says to use. That's what I always use as well.
But grease should do the job too!
01-04-2023, 09:09 AM
+1 for motor oil, but I've also heard of people using straight gasoline, too. Not sure why?
01-04-2023, 10:05 AM
Real Name: Jeremy
Real Name: Jeremy
x3 on motor oil..I've rebuilt/swapped numerous injectors in my day(not for Toyotas) and that's all I ever use. Only need a drop.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
01-04-2023, 11:01 AM
Used some motor oil on mine, no problems!
IG: @lowtege
01-05-2023, 10:10 AM
Real Name: Joe
Real Name: Joe
FSM calls for spindle oil or gas. I used gas on mine when I swapped them out, no leaks.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
01-05-2023, 12:17 PM
Real Name: Caleb
Real Name: Caleb
After a few ripped o rings on my 3zve, the napa guy reccomended this stuff and it is now my go to. It works so well!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
01-05-2023, 01:08 PM
Real Name: Tim
Real Name: Tim
The Toyota factory service manual recommends using gasoline as the lubricant for the o-rings.
I think silicone grease is the way to go, since that's what MotorWest Performance sends with their injectors and they're experts in the field of injectors.
01-05-2023, 01:44 PM
Very well. At least I didn't add something misleading, so that's good. If I ever need to do an injector job, I'll be sure to keep this in mind. 322K strong and counting!
01-05-2023, 02:31 PM
Real Name: Curt
Real Name: Curt
Motorwest includes a couple extra o-rings also, along with the lube as others have mentioned. You'll be set.
