Old 01-12-2023, 10:20 AM #16
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Originally Posted by Texmax View Post
Weird parasitic draw solved found to be all the idiots in D.C. running the country into the ground.
Glad you got your issue resolved. :TU
Nailed it.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 01-12-2023, 12:12 PM #17
Originally Posted by thegipper View Post
I checked the voltage again this morning, it's been disconnected from the vehicle over night and it's dropped down to 10.3v
Case closed, bad battery. I'll have to exchange it this weekend. This time, I'll bring my volt meter with so I can check the batteries on the shelf to make sure the one I pick is fully charged.
Thanks everyone
Good to hear.
Old 01-12-2023, 07:10 PM #18
thegipper's Avatar
thegipper's Avatar
I found the date code on the battery. It was made in Jan of 2021 so its been sitting on a shelf for two years.
Probably explains why it won't hold a good charge anymore.
Sent from my SM-N975U using Tapatalk
2011 Camry SE V6
Old 01-12-2023, 09:33 PM #19
It’s not good letting starter batteries go below 80% charge. That’s when the sulfates ungell and start sticking to the plates.
Old 01-13-2023, 05:48 PM #20
thegipper's Avatar
thegipper's Avatar
I exchanged the battery and with the new one, she fired right up. Should be all good now but if something changes, I'll report back.
2011 Camry SE V6
Old 01-14-2023, 10:18 AM #21
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Where did you manage to find a 2 year old AC Delco battery for sale? Wow!
Well, never shop there again and always check date codes; 90 days old is the maximum, less than 30 is ideal. if you have a question about the status of a battery the best way, if you don't have your own tester, is to take it to a local parts store and let them test it. It's free and saves you a lot of trouble.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 01-16-2023, 09:20 AM #22
thegipper's Avatar
thegipper's Avatar
I got the battery at Menards. AC delco doesn't put a simple date sticker on their batteries (01/23 etc). So when I was buying it, I didn't take the time to google search how to find the date code on the sticker (mistake). After I was having issues, I looked up the date code for AC delco batteries and found that it was two years old (01/21).
When I exchanged it, I brought my volt meter and checked the newest battery they had which was from October of 22. Measured 12.56 volts. The oldest battery they had on the shelf in that size was from 09/22. Not sure how a two year old battery was still on the shelf but I managed to get it.
2011 Camry SE V6
Old 01-16-2023, 10:12 AM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am glad you got issue fixed.
Old 01-19-2023, 08:46 PM #24
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Yeah, no fault on your part. Terrible that they aren't maintaining their stock. Well, you're armed with some battery knowledge now. Shop where they keep up with their battery's age and rotate out old ones. I am fortunate to have access to an Interstate store as well as Batteries plus Bulbs. I also found that the local Toyota dealership's price on the Toyota battery was competitive with big box store batteries, and fresh.
Amen to getting to the root of the problem and getting it fixed.
Rich
Kentucky
battery , days , draw , truck , ultragauge
Parasitic draw draining the battery/multi meter assist needed zgensler31 3rd gen T4Rs 28 01-17-2022 04:33 PM
At a loss - Parasitic Draw on Battery (mechanics baffled)) Smitty114 4th Gen T4Rs 15 03-03-2021 06:07 PM
strange parasitic draw Frank13F 3rd gen T4Rs 21 01-24-2019 01:24 PM
Parasitic draw help needed runnerw 3rd gen T4Rs 1 06-24-2015 01:14 AM
Parasitic Draw in JBL amp cotten Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-15-2008 01:09 AM
