Old 01-20-2023, 07:44 PM #16
og80gt og80gt is offline
og80gt is on a distinguished road
When I had a metal on metal grinding sound on my other car, it was a bad wheel bearing....
2000 4runner - 5 spd, 4x4, ARB front, Toytec Aluma 3" lift, SPC UCA's, EimKeith PCK, OCD Sway Bar Endlinks, 4X Innovations Rock Sliders, Victory 4X4 Front & Mid Skid Plates, Ray's TE37XT's, 17x8.5 -10's, Mickey Thompson Baja MTZ P3's, LT285/70/17
2000 E39 M5 - Dinan S2
1980 Celica GT - still building
1979 930 Turbo - stock
og80gt is offline   Reply With QuoteReply With Quote
Old 01-20-2023, 07:59 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Wheel bearing can make metal grounding sound or they will whine and howl like crazy before they come apart and fail.
Hope this helps. :-) If that wheel bearing is bad, the cv will be moving around up and down left or right against that bearing. Lots of times, you can feel roughness when spinning them as well too.
Old 01-21-2023, 08:24 PM #18
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
So after I took the knuckle off the cv axle and put it back together, the metal grinding sound went away. The clicking is still there though and it’s definitely from the passenger side with the Napa axle I just replaced. Had somebody stand outside the vehicle to confirm that for me. The clicking gets progressively faster as the vehicle moves faster. Is that the bearing? Gonna head home and jack it up to check for play in the tire. Will update soon.
stevew092984 is offline   Reply With QuoteReply With Quote
Old 01-21-2023, 10:42 PM #19
Ok, so I jacked the front end up again and found the drivers side tire had a bit of play in it when I shook it horizontally (from 9 to 3), but not the passenger side, the one that’s making the clicking noise. I’m at a loss here, not sure what’s going on. Maybe both wheel bearings need to be replaced. 🤷🏼
Old 01-22-2023, 09:05 AM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If you have play in the drivers 9 to 3 position. Make sure the inner tie rod is not causing it. As it could be tie rod play instead of wheel bearing play in the 9 and 3 position.
The clicking I see has not been narrowed down or found yet.
Old 01-22-2023, 09:31 AM #21
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Exactly what Brillo said.
Generally speaking…….
Movement in wheel @ the 9-3 position points at worn steering components.
Movement at the 12-6 position points to wheel bearing wear.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-22-2023, 03:38 PM #22
Here’s a link to a video of the noise I’m getting.
Clicking noise from front of vehicle - YouTube
Old 01-23-2023, 11:02 AM #23
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Does it click only in corners, or when going straight as well?
It sounds like a pretty lightweight noise, but sound recording is often iffy on a phone.
JohnMc is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 02:58 PM #24
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Good advice, but always verify that the play isn't just the steering wheel turning as well. I went down a rabbit hole because of that one time...
Old 01-23-2023, 03:54 PM #25
jlaho jlaho is offline
jlaho is on a distinguished road
You had mentioned that you noticed a damaged inner seal on the knuckle? That would point me in the direction of the wheel bearing. Logic being a compromised seal would allow oil out and contaminants in. Or possibly the bearing failed first, and the unsupported/misaligned axle damaged the seal.
Difficult to say without seeing it. I would personally remove the cv axle from the hub and rotate the hub by hand feeling for any play, grinding, tight spots as others have mentioned.
If the bearing is good and the cv axle is good (they can be disassembled to inspect if need be), my next suspect would be the differential.
jlaho is offline   Reply With QuoteReply With Quote
Old 02-23-2023, 11:49 PM #26
nutsaboutsoccer's Avatar
nutsaboutsoccer nutsaboutsoccer is offline
nutsaboutsoccer is on a distinguished road
You can have just one ball in the bearing gone bad an get a clicking sound. I've found that to be true on any front wheel bearing 2wd or 4wd.
nutsaboutsoccer is offline   Reply With QuoteReply With Quote
axle , clicking , couple , replaced , side
CV axle clicking sound ralfk 3rd gen T4Rs 7 10-12-2019 08:06 AM
New reman. CV axle; Left turn clicking. dasrowboat 3rd gen T4Rs 14 10-31-2017 08:24 PM
07 V8 Exhaust Manifold Clicking / Replacement Questions shinsain 4th Gen T4Rs 7 07-18-2016 04:39 PM
Questions: Clicking CV axle, leaky outer tie rods, leaky ball joints, etc. econhonda 3rd gen T4Rs 3 05-16-2011 08:25 PM
