Anything is possible, the question is, do you want to add the complex circuitry in-order to have that feature, even if it was an OEM option, sounds like more wear, tear and complexity for nothing, personally the less wiring the better in my world. @joetr4 If it says you have an immobilizer around the ignition you got the 99+ OEM ECU coded security system and it is impossible to start or program without a paired key, and you can pair no more than 3, US port installed RS3000 is under the driver seat from what I've heard and that's all I know about it.
