Old 01-27-2023, 05:38 PM #1
Shlop's Avatar
Shlop Shlop is offline
Real Name: Joe
Shlop is on a distinguished road
Shlop's Avatar
Real Name: Joe
Heat Troubleshooting
Hey Guys,
So one of the major issues right now with my new to me 3rd gen 98 Limited, the heat is not working correctly. It takes forever to heat up, and when it gets to temperature it is luke warm, at best. It blows out the front, not sure about the back? Because the entire car fogs up immediately when its cold outside (like it has been lately) and not even anti-fog helps too much but i think that might just be because it's old and expired.
What might I be able to do to troubleshoot the issue and see if I can fix it myself?or just be able to find out and save on diagnosis if the job isnt within my realm of ability.
Any insight would be helpful, I'm a visual learner so anything that I do to my car i usually need a video or some reference. I would ideally like to come up with a Step 1, Step 2, etc plan to figuring out most possible issues, or just whatever sequence makes sense while I'm at certain points of the troubleshoot.
TYIA
Shlop is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 05:59 PM #2
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Originally Posted by Shlop View Post
Hey Guys,
TYIA
There could be a ton of different reasons. But let's start with the thermostat. Has it been replaced yet?
Old 01-28-2023, 12:59 AM #3
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Grab the heater core lines once the car is fully warmed up. If the inlet is hot but the outlet is cold then you have a clogged heater core. That’s the easiest thing I can think of to rule out right off the bat
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 01:15 AM #4
Shlop's Avatar
Real Name: Joe
Shlop's Avatar
Real Name: Joe
I have service records dating back to '08 with no mention of the thermostat or really anything obviously related to the heat
Old 01-28-2023, 01:16 AM #5
Shlop's Avatar
Real Name: Joe
Shlop's Avatar
Real Name: Joe
Awesome will go to rule that out first thing tomorrow then.
Old 01-28-2023, 01:54 AM #6
Shlop's Avatar
Real Name: Joe
Shlop's Avatar
Real Name: Joe
Ok so with the responses and then having a direction on what videos to watch, I've come up with this plan for troubleshooting:
1. Coolant level check
2. Check valve function and hose temps towards the heater core to see if its clogged
3. Check Thermostat
Based on those results ill have to do either an air flush on the coolant lines, unclog the heater core, or replace the thermostat or any combination of some or all of those things
Am I missing a possibility?
Old 01-30-2023, 11:32 AM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
3. Check Thermostat
Could also be a problem with the temperature blend door or cabin temp sensor as well.
Also keep in mind that the temp gauge in the instrument cluster has a very wide range and will stay in the same spot from around 140*F to 220*F so it's not really a good way to gauge that the engine is at operating temperature. You really need an OBD scanner or similar to see engine temperature from the ECM. It takes my 4Runner about 10-15 minutes of driving to get the engine warm enough to have heat.
Old 01-31-2023, 11:49 PM #8
nissanh nissanh is offline
After you get the engine to working temp, allow the water into the heater core. Check the temperatures of inlet (connected to the flow valve) and the outlet. There should be a significant temp difference if heat is removed at the heater core.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 02-02-2023, 04:08 PM #9
Another note -
Are you using the 'defrost' mode? If so, it automatically turns on the AC to dry the air.
Also, you should be using outside (fresh) air setting for most conditions. Recirculating is find while things are initially warming up, but otherwise you are just keeping all the moist air inside the cabin.
Possibilities:
- Mechanical issue (thermostat)
- Electrical issue (bad control unit)
- User error (wrong settings)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
car , heat , issues , step , troubleshoot
*Heat On*: Heat blows on passenger side, cold air blows on driver's side biv117 4th Gen T4Rs 4 12-21-2023 07:09 PM
Another No Heat/Warm heat thread.. please help troubleshoot bentos1 3rd gen T4Rs 39 12-08-2022 12:23 PM
No heat diagnosis and solution, heat blend door servo actuator 4by4runr 4th Gen T4Rs 4 09-15-2019 09:10 PM
Cold heat coming out but auxiliary heat? Gremcat Classic T4Rs 4 11-19-2014 09:57 AM
Help troubleshooting rlsmithtech 3rd gen T4Rs 5 12-03-2011 07:41 AM
