Old 01-22-2023, 05:49 PM #1
Anthrax Anthrax is offline
Anthrax is on a distinguished road
Locker light flashing but engaged
98 runner. When I turn the rear locker on it seems to engage and disengage fine and quickly but the light never stops flashing. Not sure if maybe it's not engaged 100% or what the issue could be
Anthrax is offline   Reply With QuoteReply With Quote
Old 01-22-2023, 06:14 PM #2
spartacus's Avatar
spartacus's Avatar
Flashing in 4lo means ready to engage and then once the rig starts to roll itt should go solid. You can only engage the locker in 4lo or to engage it on demand, look up blue grey wire mod.
Old 01-22-2023, 07:37 PM #3
Shlop's Avatar
Shlop Shlop is offline
Real Name: Joe
Shlop is on a distinguished road
Shlop's Avatar
Real Name: Joe
Whenever my locker is engaged the light on the dash is always flashing, its never solid. When it's off the light goes off from flashing. Is that not supposed to be the case?
Shlop is offline   Reply With QuoteReply With Quote
Old 01-22-2023, 08:13 PM #4
I've done that mod. It seems to engage and disengage fine just never goes solid and is always flashing.
Old 01-22-2023, 08:13 PM #5
Supposed to be solid. Or at least has in every other one I've seen with a locker
Old 01-22-2023, 08:51 PM #6
spartacus's Avatar
spartacus's Avatar
It could be the locker detection switch on the transmission.
Faulty 3rd Gen eLocker Switch
Old 01-22-2023, 09:21 PM #7
JohnMc JohnMc is offline
JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light
/\ /\ /\ Pretty sure that will be your issue up there /\ /\ /\. On my factory locker, the light will remain flashing when you press the locker switch until the locker actually engages, then it goes to a solid light. While it's flashing, keep doing S-turns to help it engage, and if you're already into a situaion, be super gentle with it until it goes solid.
Without the limit switch to tell the ECU that the shift collar is actually engaged, it will assume it's still waiting for the teeth to get in the right spot on the collar to engage and keep flashing the 'in progress' light.
JohnMc is offline   Reply With QuoteReply With Quote
engaged , flashing , issue , light , locker
E-locker light not flashing and not lit...but locker still engaging??? TheHolyCannoli 5th gen T4Rs 19 10-20-2020 09:21 AM
Rear e-locker stuck engaged MSRP. 3rd gen T4Rs 7 09-05-2018 08:39 AM
Popping/thunks in steering wheel while 4-LO/locker engaged? DreadPirateMoyer 5th gen T4Rs 13 08-26-2016 10:36 AM
Rear E-Locker - Leaving Engaged While Offroad Koko4 3rd gen T4Rs 12 01-01-2015 09:26 PM
High Speed with E-Locker Engaged? Stockwell45 3rd gen T4Rs 3 04-20-2012 10:03 PM
