Originally posted by mike1305
okay i read about what he did, i'm having the same problem, but i tried to get the panel off but i didnt want to break anything. ccam someone elaborate on what exactly to do?
Is the entire hatch dead or just the window?
If just window:
-make sure the window lock button is not on
-make sure the wiper is seated in its 'rest' position
-check the fuse (driver side left kick panel, left column middle, 20 amp fuse, yellow)
If the whole thing is dead:
Lift the hatch open. Remove the little plastic piece by the nylon handle. Use a 10mm socket wrench to undo the screw (remember its orientation for later). The whole hatch panel is held in by clips. Run your fingers along the hatch's bottom edge and pull a little until you find a loose spot. I found one that wasn't as tight as the others and slowly, evenly started to pull. You'll find that once you have one out they all pop out relatively easily. If you can't get the first one going use something flat and wide to pry it off. I didn't pull the entire panel off, I left the top (by the weather stripping for the window) attached. With the panel flapped open you will see the plugs just like in the picture on the Yotatech post linked above. The white one wasn't seated for me and that was all it took. Just squeeze each one and make sure its seated.
Let us know how it goes.
