01-23-2023, 12:28 PM
Body Lift Visibility
I'm shopping for front and rear offroad bumpers.
On 33's currently but I might want 35's in the future, so I would like to get the body lift now, because the bumpers are built to compensate for the body lift.
Does a 2" body lift give you those gaps between the body/frame big enough to see daylight through the other side of the body?
Are there any other odd-looking visual indications of a body lift (such as the tailpipe's spacing from the body)?
Is there any reason i might consider ordering the bumpers for no body lift and deal with it in the future when i actually want 35's? (this option seems to paint me into a corner)
01-23-2023, 12:45 PM
official vendor
official vendor
Here's my truck with a 1" body lift - you can see daylight between frame and body:
01-23-2023, 01:03 PM
Real Name: Patrick
Real Name: Patrick
Do you have any photos of it at ride height with tires on? I'm assuming it's much less noticeable, but I've been wrong before lol
01-23-2023, 01:57 PM
No worse than any Full size pickups from this era. You can make some gap guards pretty easy if it bothers you much.
The 4Runner Show
01-23-2023, 02:04 PM
official vendor
official vendor
Depends on the view angle - you can definitely see the gap at some angles, at least with my 2" suspension lift:
01-24-2023, 11:24 AM
Here's a kit you can buy, if you want, to cover the gaps: Daystar Body Gap Guard
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
01-24-2023, 12:48 PM
This is what a 1" body lift looks like in terms of the gap. I have LC80 springs in the rear as well. All things considered, it doesn't look horrible, but I imagine a 2" will probably look... different...
01-24-2023, 01:11 PM
Are there any other odd-looking visual indications of a body lift (such as the tailpipe's spacing from the body)? ...
The rear bumper is attached to the body, so more of a gap between bumper and hitch. Front bumper is attached to frame, so there is a gap that the kit must account for to 'look' right. And as others said there is space above wheel wells depending on suspension lift too.
01-25-2023, 01:58 PM
The thing is even with a 2” BL I’d bet you’ll still rub with 35’s. Maybe not quite as much as without a body lift though. But yea I think you’ll still have to chop the firewall if you want full up travel lock to lock. I would say the majority of people who run body lifts go with 1”, myself included.
01-27-2023, 01:11 PM
Yeah I'm definitely planning on tubbing if I go 35s.
I think the question now is will 2" body lift mean I have to do significantly less cutting? Because if its the same amount of work I'll just go 1"
