Old 01-23-2023, 12:28 PM #1
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
Body Lift Visibility
I'm shopping for front and rear offroad bumpers.
On 33's currently but I might want 35's in the future, so I would like to get the body lift now, because the bumpers are built to compensate for the body lift.
Does a 2" body lift give you those gaps between the body/frame big enough to see daylight through the other side of the body?
Are there any other odd-looking visual indications of a body lift (such as the tailpipe's spacing from the body)?
Is there any reason i might consider ordering the bumpers for no body lift and deal with it in the future when i actually want 35's? (this option seems to paint me into a corner)
DJRodriguez88 is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 12:45 PM #2
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Here's my truck with a 1" body lift - you can see daylight between frame and body:
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 01:03 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Do you have any photos of it at ride height with tires on? I'm assuming it's much less noticeable, but I've been wrong before lol
Old 01-23-2023, 01:57 PM #4
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
No worse than any Full size pickups from this era. You can make some gap guards pretty easy if it bothers you much.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 02:04 PM #5
official vendor
official vendor
Depends on the view angle - you can definitely see the gap at some angles, at least with my 2" suspension lift:
Old 01-24-2023, 11:24 AM #6
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Here's a kit you can buy, if you want, to cover the gaps: Daystar Body Gap Guard
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 12:48 PM #7
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
This is what a 1" body lift looks like in terms of the gap. I have LC80 springs in the rear as well. All things considered, it doesn't look horrible, but I imagine a 2" will probably look... different...
Untitled
Untitled
Old 01-24-2023, 01:11 PM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Are there any other odd-looking visual indications of a body lift (such as the tailpipe's spacing from the body)? ...
The rear bumper is attached to the body, so more of a gap between bumper and hitch. Front bumper is attached to frame, so there is a gap that the kit must account for to 'look' right. And as others said there is space above wheel wells depending on suspension lift too.
Old 01-25-2023, 01:58 PM #9
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
The thing is even with a 2” BL I’d bet you’ll still rub with 35’s. Maybe not quite as much as without a body lift though. But yea I think you’ll still have to chop the firewall if you want full up travel lock to lock. I would say the majority of people who run body lifts go with 1”, myself included.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 01:11 PM #10
Yeah I'm definitely planning on tubbing if I go 35s.
I think the question now is will 2" body lift mean I have to do significantly less cutting? Because if its the same amount of work I'll just go 1"
35s , body , bumpers , future , lift
3rd gen body lift-$50/body mount bushings- $75 jstim For Sale: T4R Items 23 09-03-2016 05:30 PM
Polyurethane Body Mounts without Body Lift ChildrenOfBodom 3rd gen T4Rs 18 02-21-2016 08:05 PM
To lift the body or to not lift the body, that is the question kishanSR5 3rd gen T4Rs 49 03-24-2015 12:53 AM
Polyurethane replacement body mounts with body lift opinions? ellner357 3rd gen T4Rs 0 02-02-2013 12:42 PM
To body lift, or not to body lift, that is the question: Krazynative Engines / Suspension / Wheels / Tires / Audio / Accessories 14 06-21-2012 06:05 PM
