Old 01-24-2023, 10:45 PM #1
McLoven1t562 McLoven1t562 is offline
McLoven1t562 is on a distinguished road
Smelling Fuel At Cold Starts
Hey everyone, so I've been trying to diagnose this issue for awhile now but every time I do a cold start, I can smell gas fumes in my vehicle up until the engine warms up.
So far I've already performed a smoke test, visually inspected fuel lines for leaks, replaced fuel filter, installed brand new oem EVAP Canister and the problem still continues.
I doubt it'd fix the problem, but I do plan on replacing my fuel pump assembly just because I have no clue when it was (if ever) replaced so I plan on dropping the tank for a cleaning and installing a new pump too.
Love to hear some suggestions or possibly if anyone else has experienced this problem before.
Thanks In Advance
McLoven1t562 is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 02:30 AM #2
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
It's normal for cars to smell worse when they're started up. The catalytic converter isn't warmed up. To make it even worse, on startup engines run rich to account for some factors so the combustion isn't as complete making the exhaust even more smelly.
And to top it off, 3rd gen 4runners are from a different time, the fuel injection technology has progressed a lot. I've had 2 people comment about how smelly my cars exhaust was, even though my 4runner is well looked after and passes CA smog just fine.
Because it goes away, if something is leaking it's probably a leaking exhaust rather than fuel. Check under your manifolds heat shields for cracks. You could test it and see if it's to the point where a carbon monoxide detector would sound.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 12:33 PM #3
Oh ok gotcha, yea I do typically go out during the cold months and let it run for 5-10 minutes because I just figure since it's an older vehicle, I should let it heat up a little before driving compared to newer cars where I'd check an email, pick a song and leave 1 minute after start-up lol
Sounds good though, I'll take a look at the exhaust components just in case.
Thanks for the feedback
cold , fuel , plan , problem , replaced
Fuel Smell at Cold Starts McLoven1t562 3rd gen T4Rs 20 10-29-2022 02:06 PM
High idle on cold starts on cold days texadelphia 3rd gen T4Rs 8 10-12-2021 04:43 PM
Bad misfire on cold starts hawkmanjr 3rd gen T4Rs 24 01-19-2020 12:38 PM
Low Idle on Cold Starts 4RUN0326 3rd gen T4Rs 9 02-03-2019 12:24 AM
Long-ish starts cold, too-quick starts warm. mckennar 3rd gen T4Rs 4 10-18-2016 12:20 PM
